Oh my, look at how big you are...
Cuz I'm unloading the TVS and looking for ideas to mix around. Let's just say it's gonna be wicked lol. I just don't want to have the M62 back on it haha. Even if I would only use the blower first half of the RPM's (hint hint)
Instead you should have Jr fab you a plate for a mp112... Flows up to 800cfm before overspinning
I think the plate Jr has been fabbing for the mp90 will directly bolt to the m112.
lol. until dynoed, its your assumptions vs my assumptions.
if jr has access to an mp62, see if we can get some dyno time. run 2 identical tunes with only the blower being different on the same day (swapping the blower is 30 mins anyway). See if theres any difference in power, or IATs
H62 > MP62, and the H62 only made 20 more horses than the m62 when both were on maxed out setups.
there has been no testing in the lsj community for the MP62
I'll have to take you for a spin
dyno'ing very soon, I won't touch the tune until I'm pulley'd down
magnuson makes MP cases, opposed to using the eaton case. They sometimes use different inlets. Otherwise, nada.
Its like this (obviously these are 2300 series),
magnuson's case:
harrops case:
All the rotors are sourced from eaton, but other companies like harrop and magnuson can make their own cases for the rotors.
heres the m62 vs mp62
same thing, except the maggie does not have a fixed inlet. It is modular so they can make inlets for each one of their aftermarket applications.
Additionally, they sometimes tweak the exit, but the MP62 exit is more narrow than the m62 exit, so i dont see this as a plus. It has more area where it isnt needed (near where the silencer ports are on the eaton) and less area everywhere else
magnuson's case:
harrops case:
MP62 outflows the m62 by 100cfm by 16k and remains efficient
Eaton m62 hangs loose like wizards sleeve! It's not nice!
EATON M62:
Magnuson Products 62
EATON M62:
lol. steve, according to your graphs, at the same RPM, the m62 outflows the mp62 by a few cfms. The only reason the mp62 peaks 100 higher is because they rev it 2,000rpms higher than eaton revved the m62.
Let me grab my magnifying glass..... :They both flow 450cfm @ 14k: -_-
and who spins there m62 @ a measely 14k? Anyone who makes any power out of the m62 over spins it. unless your turbo tim... even he is over spinning it tho w/ the 2.7
**** even Ebristol on e-85 overspins his m62 to make any power
Not trying to play grab ass here w/ which 62 is the victor. That's clearly visible
/END
MP90 THREAD BACK ON TOPIC
/END
additionally, your graphs show the m62 has IATs roughly 30 degrees cooler, given tha the m62 deltaT is 140-180 and the mp62 deltaT is 180-200 throughout their pulls.
And EVERYONE spins their m62 at a measly 14k at some point. You cant look at peak numbers unless you're trying to make a dyno queen. Gotta look at the whole power band.
this all started because wicked should know the facts if hes gonna go twin charged. there is no benefit in the mp62 vs m62, especially given that he already has an m62....
Wouldn't the pulley dictate what rpm the supercharger is spun at in less than 1000 engine rpm
It shouldn't take the m62 3k to redline to make the blower spin from 6k to 16000. Wouldn't that be more like a centrifugal?
Peak boost is achieved around 4200-4000 rpm on a m62 and then plateaus until redline. Wouldn't that mean the blower is running at it's maximum rpm, given what pulley it's using?
It shouldn't take 3k to redline to make the blower spin from 6k to 16000. Wouldn't that be a centrifugal?
with a 3" pulley, 6k to 16krpm blower speed is 2770rpm-7398rpm engine speed, so thats actually exactly what it takes
Now i feel you have a severe misunderstanding of how belt driven superchargers work.
Good to know, ty
This is pretty cool... MP90 Doesn't peak boost until roughly 6200 rpm
Cool so if I do (6500rpm)*(6.5" crank) / (3.0" pulley) = 14083.33 MP90 S/C rpm
Which will net me my desired 600cfm by redline
And the blower will finish @ it's peak efficiency. I'm sure the meth is helping too
I didn't realize how much better my mp90 investment was over the m62 and mp62 until now. That little formula is great
And the blower will finish @ it's peak efficiency. I'm sure the meth is helping tooI didn't realize how much better my mp90 investment was over the m62 and mp62 until now. That little formula is great
Although I highly believe with further tuning you can net more than 20whp over the M62 with the H62. That 20whp dyno test was performed by Intense. All they did for the test was perform a direct swap of a M62 with the H62 w/o further tuning, and gained 20whp. I myself have yet to even push the blower to the limits and see what it can do. Its no TVS by any means, but its still a neat piece.
it dictates what rpm the blower spins at at all engine rpms
ALL superchargers rpm is a finction of engine rpm. pulley size is just a scalar, therefore max blower speed occurs at max engine speed, minimum blower speed occurs at minimum engine speed, and the relationship is directly proportional.
no. the blower doesnt reach peak rpm until you shift. Your blower speed is: (engine rpm)*(6.5)/(pulley size).
Good Data... Would Read Again
