oil pan
Old Oct 25, 2009 | 04:41 PM
harryresh's Avatar
oil pan
has anybody had much trouble trying to get there oil pan off. im installing forged aluminum pistons and having a helluva time getting my pan off. i believe i have all of the bolts off but its stuck fast!
Old Oct 25, 2009 | 04:47 PM
Red07SSNA's Avatar
It is RTV'd all the way around...makes for a good seal...
You didn't miss any bolts did you?
Old Oct 25, 2009 | 04:51 PM
slowswap's Avatar
I would personally use a screwdriver and try to gently break the seal. I wouldn't use a lot of force unless you're dead sure you have all of the bolts out.
Old Oct 25, 2009 | 06:53 PM
damien's Avatar
Yea, I had to use a screw driver but I was positive everything was out. Did you get the one that bolts to the IC pump?
Old Oct 25, 2009 | 08:12 PM
mrbelvedere's Avatar
the pan is set on dowel pins and it fits very tight around them take a rubber mallet and smack the pan a couple of times then use a screwdriver on an edge to start seperating the pan from the block and dont use just any sealant get the gm stuff made for the job so you dont have any leaks
Old Oct 26, 2009 | 06:46 AM
harryresh's Avatar
im sure i have all of the bolts out including the IC pump. i did smack it hard with a rubber hammer but i guess ill have to keep trying...
Old Oct 27, 2009 | 01:15 PM
harryresh's Avatar
i got it off. now im having trouble installing the spirilox clips
DarrenGC
Dec 24, 2021 01:55 PM
biniecki
Oct 25, 2015 02:23 PM
717ssbalt
Oct 2, 2015 04:01 PM
importkiller
Sep 30, 2015 07:18 PM
dennis69
Sep 28, 2015 02:16 PM
