Running 10.5:1 pistons
Old Jun 20, 2007 | 12:11 AM
KillerBee's Avatar
Hey my friend 1ftss is running 10:1 compression pistons and that thing hauls ass now and he is running pumped gas like 93
Old Jun 20, 2007 | 12:14 AM
victory_red_SS's Avatar
LSX RWD S/C conversion
Originally Posted by Onyxd04Redline
Wow some people who actually think like i do. I was blasted over at the redline forums because i'm going with SRP 8:1's and a custom whipple at 20psi.
He was one of them trying to tell me that i was "Retarded" for wanting to drop compression that much and i should stick to around stock compression for 20psi of boost.
One of the reasons why i came over here. Lots of knowledgeable people here.
It was because of way to much of that type of attitude, that I choose to no longer participate on the redlineforums.
Old Jun 20, 2007 | 02:38 AM
Onyxd04Redline's Avatar
Originally Posted by Blown 4-banger
Is That Really Tempe Az I See On Your Location!?!? **** Man Im From Chandler!!!
Blown.. I'm leaving for tempe on thursday.
How much boost is he running and i imagine he's using the stock eaton. If i tried to run 10:1 and 20psi from a 1.6L whipple on shitty az 91 octane the engine would explode within minutes.
Old Jun 20, 2007 | 03:11 AM
AlphaJaguar5's Avatar
Tell me, was the head of the attack on you by chance AlphaJaguar? He TRIED to blast me when I posted about my blower porting! He blasts everyone, and says he has 300 whp with no dyno to prove it.
lol, your funny
obtw, would you kinda point me in the direction of a post where I say I HAVE 300whp, I'm roundabouts but never said 100% that I was anything beside what my last dyno said and that was with a 2.7", no timing & a 10.4 A/F so me saying I have more than I did then is more than acceptable.
Also, your blower porting is asinine
Old Jun 20, 2007 | 03:13 AM
Blown 4-banger's Avatar
I try to be.
Old Jun 20, 2007 | 12:52 PM
rnjmur's Avatar
Originally Posted by SSweet06
I bought 10:5:1 pistons which Rob Archer told me he was going to do before he had to get rid of the car. Now after reading everything and I talked to Todd at Intense I don't know if I want them anymore. Should I sell them or give them a try? I really don't want to run 100 octane. I run only 94 now so I don't really want to go above that. Any advice would be appreciated.
You *MAY* be able to get away with 94 octane using 10.5 pictons, but you will have to run stock boost or less to avoid getting knock though.
Old Jun 20, 2007 | 12:58 PM
06blackg85ss's Avatar
stick with stock compression or lower and go turbo... best way to make power plain and simple on the these motors.... no arguments about it. Unless you want to stay s/c'd... then well... we've had this argument before.
Old Jun 20, 2007 | 01:46 PM
chevysalesman614's Avatar
Talking ATTENTION! Noob question alert!
whats the stock LSJ compression ratio?
Old Jun 20, 2007 | 04:12 PM
I believe 9.5:1
Old Jun 20, 2007 | 04:30 PM
KillerBee's Avatar
We dont know he is waiting for it to get tuned so as he does i am sure he will post a thread on here about it
Old Jun 22, 2007 | 04:06 PM
  #36
I believe 9.5:1
You are correct. The pistons are a Mahle hypereutectic alloy.
You can get away running 14:1 pistons it just depends on how much boost you wanna run.
Last edited by AlphaJaguar5; Jun 22, 2007 at 04:06 PM. Reason: Automerged Doublepost
Old Jun 22, 2007 | 08:08 PM
  #37
Witt's Avatar
Also timing.
You are going to run into ignition trouble with too much compression. Richer than rich best torque and high compression and you substantially increase your chances of spark issues.
Old Jun 23, 2007 | 03:44 AM
  #38
Which in that case would be zero. Not even race cars use that high compression with boost. The 1450 hp ecotec motor uses 10.8:1 compression and over 50 psi boost. Top fuel motors run a whopping 7.5:1 compression and 45 psi boost!
Old Jul 13, 2007 | 03:47 PM
  #39
M88ArRamadi's Avatar
ALL my mods in my garage....please look before responding..........
sooooooo.... I just got the 10.5:1 with all coating for a good deal... a really good deal .
NOW my problem is I can only get 91 octane. Should I lower my comprerssion? I plan on starting with about 10psi. Then get the fuel and spark right. From there I'll adjust boost/fuel/spark accordingly.
My HG is the last thing to get before the engine goes back together......I could really use the imput....thanks
Old Jul 13, 2007 | 04:12 PM
  #40
Witt's Avatar
IMO, you really need to see what the cams you plan on running do for your effective compression and compensate with higher static compression pistons.
If you have too high of an effective compression you may run into spark blowout issues and might have to upgrade your ignition system. I increased my static compressiojn to 10-1 myself and my 272 cams brought my effective compression right back down to stock levels. However, increasing redline to 8k rpms brought forth new spark issues that I have solved by increasing spark dwell time, however its at a cost of significantly decreased coil life span.
All in all, its a pain in the ass no matter what you do. I'm sure no matter what, you can solve the problems with a little bit of tuning.
Old Jul 13, 2007 | 04:24 PM
  #41
JBP don't give out there Stage 2 cam specs...... ..what do I do now???
Old Jul 13, 2007 | 04:30 PM
  #42
Witt's Avatar
Somewhere I saw a few specs listed, maybe in their old group buy thread. Try to call them and bug them, I'm sure they will give them up over the phone.
Here's what I found, everything except the lobe seperation angle, I would probably ignore the secondary intake specs as they are "milder" then the primaries, but I'm no expert in this:
PRIMARY INTAKE
ADV
264* 418L
@.050
209*
SECONDARY INTAKE
ADV
256* 417L
@.050
202*
PRIMARY EXHAUST
ADV
256* 417L
@.050
202*
Old Jul 13, 2007 | 04:44 PM
  #43
With 91 octane, you will not be able to run boost. That compression ratio is way way to high for any kind of boost with THAT shitty gas.
Old Jul 13, 2007 | 04:48 PM
  #44
Witt.....I think that is for their Stage 1 cams...but IDK.....I'll call them
4-banger......so should I get the .040 HG? That should yeald me around 10.0:1
Old Jul 13, 2007 | 09:35 PM
  #45
Lowering compression with the head gasket is never a good idea, because it messes with the quench of the piston and deck. You can do it that way, but you may have problems with knock.
Old Jul 13, 2007 | 09:48 PM
  #46
NJHK's Avatar
and the timing chain
Old Jul 13, 2007 | 09:57 PM
  #47
I don't think an extra .17 inch would do much to the timing chain, but it definatly could as well
Old Jul 13, 2007 | 10:20 PM
  #48
I had the .040 on there last time....that's all cometic made at the time. The timing chain fit fine. I don't understand how a thicker HG produces knock. Little info please.
Old Jul 14, 2007 | 02:02 AM
  #49
Witt's Avatar
Some engines have quench style pistons and heads. Ecotecs are not that type. No more than .045" clearance is needed for proper quench, something the Ecotec lacks.
Old Jul 14, 2007 | 02:10 PM
  #50
^^ so increasing the HG thickness won't screw up my build? I think I'm going to go with the .040" HG anyways.
This is going to sound dumb but.......I have to ask:
could I add octane booster to increase octane levels so that I can run 10.5:1 w/ a .027"??
