Soon to be another 400 hp turbo lsj
I have all ferra valvetrain, springs, retainers, valves, and a ported head, still stock cams though.
Also I am going to threadjack my own thread for a sec. Stupid question when will I no longer be a"new Member" I am member #139 out of what 35,000. Is it based on number of posts?
*small update*
We are going to top mount the turbo. My fabricator, Matt at HTP, thinks the manifold and downpipe will be cleaner with a top mount. He is going to start on it and the charge pipes this or next week.
Here are some pics of the brake booster check valve fitting I found so i could run braided hose from intake manifold to the brake booster.
Pics of the coolant return line from the turbo. I am having an aluminum coolant tank made to replace the plastic one. I still have to clamp the braided hose once we get everything hooked up. Cant see it in the pics but I also have installed ARP stainless 8 x1.25 studs in the head for the intake manifold mounting
I was just about to order the rotated mounts from Ottp but it looks like they are changing them to a new design so I going to have to wait.
Looking good Jeff, Ill have to swing by and talk to matt and check the car out!! BTW the head porting on your car?? Nice man, i had no idea you had that done around here!! Man this makes me want to have Matt fab me up a kit, Ughhhhh
First negative thing I have ever heard about HTP. He does awesome work, and takes pride in it, which is hard to find. That alone brings him much business, which makes turnaround a little longer than one would hope, but its worth it in the end.
not worth it when i take 8 months to get it done and doubles the price when its all done.... first thing he ever did for me was done fast and what i was quoted is what i paid, after talking to a previous employee of his i think there are alot of people out there with bad taste in their mouth, and im not saying he does bad work but good luck getting anything done in a timely manor, jeffs car has been there for a good 8-10 months and i bet the most work done on it was done by jeff himself...
The hose is -6
The fitting in the head is 10mm X 1.0 to -6 to replace the original banjo fitting
one -6an T
one 90 degree hose end
and 3 straight hose ends
All of this is available through several online parts stores. Summit, Jegs and others you can find part numbers there.
I need a few more hose ends to finish the install and get the supply line finished
Also I have read that the 05 pumps are weaker than the later years so I need to figure out what route to go on that front.
I should have new pics later in the week with some real progress
