Those with the SnowPerformance Kit
Old 11-13-2006, 06:27 PM
DTM2188's Avatar
Does anyone have the instructions to installing the kit? Or a link to where I could find them? Thanks in advance!
Old 11-13-2006, 07:29 PM
Blown 4-banger's Avatar
Enjoy
https://www.cobaltss.net/forums/show...ater+injection
Old 11-13-2006, 07:38 PM
DTM2188's Avatar
Awesome, thanks a lot man. How's your car doing after that problem you had with the belt?
Old 11-13-2006, 07:53 PM
Oh, that! Pshhh I fixed that the day it happened (thank god I had a spare belt). My new thing is I need to get a wideband and a scan gauge. I'm extremly worried about my car, in light of all the recent engine failures. Now that its getting colder I fear I'm running too lean. I'm not worried about knock, because when I tuned I had no knock and that was back when it was in the 80s and all I had was a cobra HE.
Old 11-13-2006, 07:58 PM
DTM2188's Avatar
Good to hear everything is back up and running well then. I also gotta get some gauges to make sure everything is running smoothly. I'm pretty sure I have a similar set-up as you do, and I'm also a little worried with all the engine problems and axels breaking. One more quick question, you can just use your windshield washer tank for the kit, right? You don't need to purchase another resevoir tank do you? Thanks again.
Old 11-13-2006, 08:02 PM
From what I understand some people ARE using the washer fluid tank. I personally don't have water/meth injection so don't quote me on that, but it certainly seems do-able, its not like it being used (I've had my car since March 31st and have yet to touch the window sprayer).
EDIT* One more thing, how you liking your header? I love mine, I just want the opinion of a fellow pacesetter user.
Old 11-13-2006, 08:07 PM
DTM2188's Avatar
Sounds good then, I should be good to go without getting a new resevoir tank then. I like the Pacesetter a lot, I felt a noticeable difference with and with the rest of my exhaust set-up, the sound is nice and deep. I've had a problem though with keeping it from getting an exhaust leak. Two times now, one of the bolt that holds it on at the top end has fallen out! But since the last time I fixed it, I haven't had any problems and that was over a month ago now. Overall I'm very pleased with it and everyone who see's it says that it is one of the nicest looking headers they've seen for the Cobalts.
Old 11-13-2006, 08:12 PM
Hmm, I installed mine over a month ago and have yet to get a leak (knock on wood). I can't tell you what kinda gains I felt. I installed the header the same time I installed my 2.6" pulley and 3" catless exhaust.
Old 11-13-2006, 08:13 PM
DTM2188's Avatar
Did you ever get to a dyno and/or the track yet?
Old 11-13-2006, 08:14 PM
Dude, I'm so broke I can't even drive my car (no gas and no money for gas)
Old 11-13-2006, 08:17 PM
DTM2188's Avatar
That sucks man. Best of luck and thanks again for the info.
Old 11-13-2006, 08:26 PM
06blackg85ss's Avatar
oh yeah man sorry about the instruction thing.... I tapped the bottom of my resevoir tank and ran the line from there (much larger capacity) kenny from c/a "misplaced" my tank that came with the kit... and I have no idea where it ended up...
oh yeah new thing going in this weekend... little 50shot to liven things up a bit til the new project is done...
also if you have any other questions on installation feel free to pm since I"ve installed a bunch of the kits already.
Old 11-13-2006, 08:29 PM
DTM2188's Avatar
No problem man, and if I have any questions I'll let you. Do you think I'll be fine just using the window washer tank for the kit? As stated above it has been done, so I shouldn't teally have any problems with it, right? Other than just having to fill it up more often.
Old 11-13-2006, 09:39 PM
window washer tank is huge man almost 2 gallons... the one from the kit was only 2 qts.... even if you run washer fluid (-20 deg) you can still wash your windows too... I personally ran a 50/50 meth distilled water mix... worked pretty damn good.. and if you use washer fluid it makes your inside of the intake a pretty blue color... lol
Old 11-13-2006, 09:46 PM
DTM2188's Avatar
Yea, I picked up some of that -20 washer fluid the other day. Looking forward to getting the kit on. I'll have dyno results from it, too. So I'll keep everyone posted on it.
Old 11-13-2006, 10:20 PM
You guys don't mind spraying washer fluid INTO your engine?!?!
Old 11-13-2006, 10:24 PM
patathSS's Avatar
I mounted my DO kit in the trunk. I love it. The only thing I want to do is run my boost switch to a spot where it can't be seen. To look at my engine bay you would never know I have W/I except for the boost switch laying there.
Old 11-13-2006, 11:50 PM
djt81185's Avatar
If you buy the cheap stuff from wal mart its just methanol and distilled water with like a 30ppm concentration of blue dye in it...its insignificant
Old 11-14-2006, 12:02 AM
Kennyspec's Avatar
I have water/meth on my car and it works great. Gets rid of a lot of knock and keeps things cool. I also used the stock washer tank as my resivoir.
anyone ever looked into water/NITROmethane?????? It has been done before and provides WAY more power that the standard water/meth but is more dangerous too.
Old 11-14-2006, 07:24 AM
I was going to try it... but due to problems with the car... I pulled the plug on that til my new motor is built (p.s. I didn't blow mine up)
Old 11-14-2006, 07:19 PM
Nitromethane + Supercharger = BOOOOOOOOOOOMMMMMMMMMMMMMM!!!!!!!!!!!!!!!!!
Nuff said...
Old 11-14-2006, 07:21 PM
hey thats what the top fuelers run... even though they the rebuild the motor after 30 sec of run time hahaha
05-28-2022 03:47 AM
thewafflesareburnt
09-30-2015 02:29 AM
yellow dragon
09-28-2015 09:49 PM
09-28-2015 12:51 PM
metroplex
09-27-2015 07:48 AM
Quick Reply: Those with the SnowPerformance Kit
