Turbo-MISSING LINK!!
Old Jul 16, 2008 | 12:30 AM
116Fanatic's Avatar
Will this work to turbo a balt?? There isn't a specific one for it but there is a universal one for external map senors? Is ours external??
http://www.racingworks.com/missinglink.htm
http://www.cartserver.com/sc/cart.cgi?item=s-3474^ML-002B^Missing+Link+Universal+External+4cyl^59.95^1^ ^^^1
Synapse Missing Link Check Valve eliminates the use of numerous check valves for a clean show quality, professional appearance. It eliminates MAP sensor related check engine lights for all forced induction vehicles. The Missing Link smoothens vacuum to boost transition, eliminating MAP sensor related misfires and protects the MAP sensor from damage due to boost operation outside the sensor's specifications. Missing Link is easy to install and comes with all necessary hardware.
Key Features:
- Eliminates boost related check engine lights
- Enforces a smooth vacuum-to-boost transition
- Eliminates in-cabin fuel vapor from combustible charge gas vented by bleed-style check valve
- Allows for infinitely adjustable boost pressures without valve adjustment
- Automatic compensation for charges in altitude and barometric pressure
- Filtered air intake for near stock idle quality and valve longevity
Last edited by 116Fanatic; Jul 16, 2008 at 12:30 AM. Reason: Automerged Doublepost
Old Jul 16, 2008 | 08:58 AM
celicacobalt's Avatar
might be something to look into to.
Old Jul 16, 2008 | 09:20 AM
116Fanatic's Avatar
Do you know if our map sensor is external? or even where it is lol..
OrangeCoba
Oct 1, 2015 10:00 PM
riceburner
Sep 30, 2015 03:54 PM
ThoR294
Sep 28, 2015 05:31 PM
jrsmith
Sep 20, 2015 07:17 PM
Josh@ottp
Sep 17, 2015 12:03 PM
