Twincharge pressure mathematical formula
I would think that you could put on a larger pulley and not deal with all the heat issues of the 2.7" pulley.
That would be my guess. Run a bigger pulley and more power from the turbo since SC steals power to make power and creates alot of heat.
i think you'll get less efficiency if you run our S/C too low, 7psi might be alright, but its made for peak efficiency around 10psi. Also, are you just directing the turbo compressed air behind the supercharger?
Sl0wbaltSS
Nov 21, 2018 11:11 PM
