Water Meth Injection
Back in the "Late Sixties" at the drag strips we'd see some cars leaving the line with the windshield wipers running..... always a sign they'd piped the windshield washer into the air intake and were running water/meth injection.
Old HP Boost technology being recycled. Steam expansion for more ponies!
just like nitrous oxide. what goes around comes around. when carbs come back. im going to be really effin happy
go to the junk yard and buy etiher a power steering containter or a window fluid container (if you want to hold more), mount it to the rear of the engine way and run your houses dirrectly from that. Its alot neater looking especially if your OCD about the way your cars looks like me and makes it simply access to work with
more harm them good... would you put a turbo on a car w/o tunning it? Its like doing this to your engine
Last edited by JM Auto Racing; Oct 9, 2007 at 03:02 PM. Reason: Automerged Doublepost
ok, i got the coolingmist kit, so Area47 here are my first questions...
1. what psi setting did you have it set at to turn on?
2. where did you mount the pump?
3. anything else i need to konw about this kit b4 i hook it up?
4. is there a pressure setting on the pump?
5. did you spray the blue window washer fluid?
thanks, John
ps sorry about all the questions. and my mods are in my sig.
thanks, John
I can answer some of your question. Mine comes on at about 6 psi, the pump is mounted under the hood on the passenger side next to the winshield washer tank, not sure about 3 and 4, and the blue washer fluid is what you want to spray.
Thanks for the input guys.
Looks like w/i is relatively new to these forums. I created the thread for input on "where and how" but the "why" questions are welcomed.
Did you get the basic boost switch kit?
1. Set it to come on low enough to start the pump early but late enough to prevent bogging.
2. The pump should be mounted lower than the water level/source. Closer to the tank is prefered.
3. Make sure you take precautions, preventing water from getting into your system while not at WOT.
4. No pressure setting on the pump, the basic kit has a hex port switch, that determines when the kit activates.
5. Color doesn't matter as much as content. Make sure you don't spray soap based washer fluid.
thanks again for the input.
thanks, John
thanks, John
Last edited by AndrewsBoots; Oct 11, 2007 at 12:02 PM. Reason: Automerged Doublepost
if i remember correctly, washer fluid is 40% meth 59% water and 1% the blue colorant... boost juice is 50/50... spraying washer fluid is just about the same and has the same affect as boost juice. it is smart to do because your bottle is already mounted for you and all you have to do is tap into it. it also leaves you room if you decide to do the dual pass endplate with opton b.
