are you a knowledgable tuner?
Old Oct 21, 2007 | 01:15 AM
exiged's Avatar
Hope so, I have a couple questions, and mind you ive never tuned a car before. With after market cam's, at least "stage2" or more aggressive (you know, the ones that require computer modifications), what exactly do you tune for? I mean is it an air to fuel ratio adjustment, or what exactly needs to be done?
What I'm getting at is, because i do have a 2.2, would the AEM F/IC be able to tune for such an application?
I'm just trying to learn, thanks for the help!
Old Oct 21, 2007 | 04:21 AM
HunterKiller89's Avatar
wilder running cams tend to throw off MAF/MAP sensors. they ythrow off the maf by movingback and forth so much, the maf counts the molecules on their way in, some of them on their way out caused by the reversion, and the same molecules on their way in again. theyre counted for 3 times. they also throw off the MAP since those idle reversions create fluctuations in pressure.
also, i believe some cams that target high RPMs are restrictive at idle and lower RPMs and your starving your engine of o2, causing a rich condition
as far as when your in the power band, you just tune to add more fuel. the cams allow more air to flow in,and you need more fuel to burn with that added air, or else you run lean.
anyone feel free to correct me if im wrong, as im not positive on the idle tuning
Old Oct 22, 2007 | 05:23 PM
exiged's Avatar
hmm sounds like its possible then?
Old Oct 22, 2007 | 05:25 PM
halfj99's Avatar
the aem unit would be able to ajust the a/f ratio to compensate for the cams
Old Oct 28, 2007 | 03:02 PM
Tigre Tuning's Avatar
rescale the break point to more points in your idle area. this will give you greater resolution under light and no throttle to you can better fine tune your afr
Sl0wbaltSS
Nov 21, 2018 11:11 PM
riceburner
Mid Central
Oct 5, 2015 09:18 PM
anotherslowlnf
Sep 29, 2015 03:52 PM
09SSlow
Sep 28, 2015 12:37 AM
OPCrer
Sep 27, 2015 08:11 PM
