Alcohol Injection Systems Alcohol Injection Systems is a Supporting Vendor
All New AIS Competition Rear Trunk Mount Water Methanol Injection Systems
Old Jan 13, 2010 | 03:06 PM
AIS's Avatar
AIS
Non Authorized / Non-Supporting
Were proud to announce the release of our all new "Competition Series" trunk mount water methanol injection systems. We designed this specifically for our racers in mind. While the tank sports a simple, clean fuel cell look from above. Its packaged with a lot of new features making it perfect for not only track use but on the street
If anyone has any questions or would like to get in in the special were running contact us at 801.447.2559.
AIS Stage 1 Competition Trunk Mount $419.99
AIS Stage 2 Competition Trunk Mount $549.99
Features Include The Following:
*3 gallon capacity
*Dimensions are 14" long (not including the 1.25" rear sump) by 10.5" wide by 7.5" tall
*Aircraft style locking cap with built in flapper vent.
*Large cap allows you to access the inside for those who want to stuff the tank with safety foam
*Built in virtual sump with dual 3/8 npt rear pick up's
*Dual pick ups allows the use of a second pump for our high horsepower guys who max out one pump - sounds crazy but it happens!
*Pump is reversed under the tank for a clean over head appearance
*Reversing the pump under the tank allowed us to also break up the floor of the tank to help control fluid slosh
Old Jan 13, 2010 | 03:08 PM
rico's Avatar
ohh yes click
Old Jan 13, 2010 | 03:10 PM
ls1fbody's Avatar
Haz l33t wheelz.
very slick... I like.
Old Jan 13, 2010 | 03:11 PM
Edubs's Avatar
Oh my, this is a nice setup...
Old Jan 13, 2010 | 03:13 PM
rico's Avatar
I think now ill be actually getting a meth kit lol . should help with the turbo
Old Jan 13, 2010 | 06:55 PM
AIS's Avatar
AIS
Sounds great. Let me know if you have any other questions or how I can help.
Rodney
Old Jan 13, 2010 | 07:01 PM
hatrickstu's Avatar
**** that is sweet. maybe one day. lol can we trade in our old tank
Old Jan 13, 2010 | 07:05 PM
ls1fbody's Avatar
Haz l33t wheelz.
seriously baller status meth kit.
Old Jan 13, 2010 | 07:11 PM
hatrickstu's Avatar
is there a built in float switch or anything? the blank tank may led to people not realizing tanks are low
Old Jan 13, 2010 | 08:05 PM
AIS's Avatar
AIS
Its not included as of yet. But we do have plenty of room to mount one next to the pump under the tank. We didn't include it to help keep the cost down as the cap assembly is super expensive alone. However, because it's three gallons. You going to be hard pressed to go through it all in one month on a Cobalt. Check it once a week and you'll never empty it. If you want a sensor it can be added.
Rodney
Were considering upgrading existing customers who have the old tank and giving them a credit if they send it in. Check back with us when your ready to switch.
Rodney
Old Jan 20, 2010 | 12:11 PM
AIS's Avatar
AIS
www.AlcoholInjectionSystems.com
Old Jan 20, 2010 | 01:13 PM
philzoot007's Avatar
is this gonna replace the old tank and set up? or are u droping the price of that package and now offering this also?
Old Jan 20, 2010 | 03:12 PM
AIS's Avatar
AIS
I have one of the white tanks available. Once gone we will no longer be carrying the white tank. If your interested in the old style give me a call and I can make you a deal on it.
Rodney
Old Feb 5, 2010 | 01:21 PM
AIS's Avatar
AIS
Competition 3 tanks are in stock now and ready to ship.
Features & Benefits Include:
*Top of the line billet mold for exact tolerances and perfect straight lines you can only get from a billet mold.
*Black shiny textured finish. Easy to clean and looks great no matter how old the tank is. No more white tanks with dirty greasy finger prints or marks on it that won't come out. Just wipe it down with armor all and the tank really shines.
*Aircraft style flush mount cap with stainless hardware. This cap assembly is very expensive and cost us a lot! We could have easily cut corners and used a cheaper plastic cap as our competitors but it wouldn't have offered the value, features or looks of this cap.
*Aircraft style cap allows the use of inserting safety foam inside the tank for the ultimate in fluid control during road racing and street use.
*Large 3/8" NPT fittings molded into the tank. We could have easily not spent the extra money it costs to engineered our mold with this feature and simply just drilled and screwed fittings right into the plastic tank as our competitors. But this would have been cutting corners again and given someone else the opportunity to out do us and make it better.
*Dual 3/8" NPT fittings allows the use of 1/2" pick up hose. Allowing our pump to out perform any competitors pump using the smaller restrictive 1/4" hose. Essential for our 1200+ horsepower customers who need every bit of their pump.
*Dual 3/8" NPT fittings also allows our tank to be used as a trunk mount 3 gallon reservoir for air to water superchargers. Not just a water methanol tank. Simply remove the plug and you can now run both feed and return lines.
*Dual 3/8" NPT fittings allow the use of a second pump for our extreme applications which require the use of two pumps. Sounds crazy but it happens.
*Custom bent aluminum mounting straps to fit the tank perfectly. Each strap is also machined for a nice brushed look. We could have just bent the straps and called it done but we didn't.
*First trunk mount tank with built in virtual sump with rear pick ups.
*3 Gallons capacity vs competitors 2.5 gallon
*Pump reversed under the tank for a clean, stealth appearance above. First and only of it's kind.
Old Feb 13, 2010 | 02:33 PM
AIS's Avatar
AIS
AIS Competition Trunk Mounts now in stock. Have questions give us a call at 801.447.2559.
Old Feb 22, 2010 | 03:01 PM
AIS's Avatar
AIS
www.alcoholinjectionsystems.com
Old Feb 22, 2010 | 05:34 PM
Edubs's Avatar
God, I want this bad, just can't justify it right now w/ having to buy a clutch...
Old Feb 24, 2010 | 01:19 AM
AIS's Avatar
AIS
No worries. The tank aren't going anywhere and will be here when your ready. Till then here are some more pics of the tank showing all the details and quality of the tank.
Old Feb 24, 2010 | 04:36 AM
mrsilent13's Avatar
man ive been looking at this kit for the last month or so...since i first heard about it...and....i have the cash right now...but im not sure if im going to need the money later....how long is this sale going for?
Old Mar 4, 2010 | 01:09 PM
AIS's Avatar
AIS
Give me a call at 801.447.2559.
Rodney
Old Mar 4, 2010 | 02:01 PM
mrsilent13's Avatar
Rodney
we already talked through email..and i think i should be getting my kit at my door today....my name is fernando...
Old Mar 13, 2010 | 07:49 PM
AIS's Avatar
AIS
How do you like the tank?
Rodney
Old Mar 15, 2010 | 02:23 PM
mrsilent13's Avatar
i actually havent even opened the box....lol. but i will get it tomorrow
Old Mar 16, 2010 | 10:01 AM
AIS's Avatar
AIS
No way.
Jan 12, 2016 12:01 AM
OrangeCoba
Oct 1, 2015 10:00 PM
nathan112i
Sep 30, 2015 07:12 PM
Sep 27, 2015 08:53 PM
