Alcohol Injection Systems Alcohol Injection Systems is a Supporting Vendor
All New AIS Competition Rear Trunk Mount Water Methanol Injection Systems
Old Jan 14, 2010 | 11:42 AM
AIS's Avatar
AIS
Non Authorized / Non-Supporting
Were proud to announce the release of our all new "Competition Series" trunk mount water methanol injection systems. We designed this specifically for our racers in mind. While the tank sports a simple, clean fuel cell look from above. Its packaged with a lot of new features making it perfect for not only track use but on the street
If anyone has any questions or would like to get in in the special were running contact us at 801.447.2559.
AIS Stage 1 Competition Trunk Mount $419.99
AIS Stage 2 Competition Trunk Mount $549.99
Features Include The Following:
*3 gallon capacity
*Dimensions are 14" long (not including the 1.25" rear sump) by 10.5" wide by 7.5" tall
*Aircraft style locking cap with built in flapper vent.
*Large cap allows you to access the inside for those who want to stuff the tank with safety foam
*Built in virtual sump with dual 3/8 npt rear pick up's
*Dual pick ups allows the use of a second pump for our high horsepower guys who max out one pump - sounds crazy but it happens!
*Pump is reversed under the tank for a clean over head appearance
*Reversing the pump under the tank allowed us to also break up the floor of the tank to help control fluid slosh
Old Feb 7, 2010 | 05:05 PM
AIS's Avatar
AIS
Competition 3 tanks are in stock now and ready to ship.
Features & Benefits Include:
*Top of the line billet mold for exact tolerances and perfect straight lines you can only get from a billet mold.
*Black shiny textured finish. Easy to clean and looks great no matter how old the tank is. No more white tanks with dirty greasy finger prints or marks on it that won't come out. Just wipe it down with armor all and the tank really shines.
*Aircraft style flush mount cap with stainless hardware. This cap assembly is very expensive and cost us a lot! We could have easily cut corners and used a cheaper plastic cap as our competitors but it wouldn't have offered the value, features or looks of this cap.
*Aircraft style cap allows the use of inserting safety foam inside the tank for the ultimate in fluid control during road racing and street use.
*Large 3/8" NPT fittings molded into the tank. We could have easily not spent the extra money it costs to engineered our mold with this feature and simply just drilled and screwed fittings right into the plastic tank as our competitors. But this would have been cutting corners again and given someone else the opportunity to out do us and make it better.
*Dual 3/8" NPT fittings allows the use of 1/2" pick up hose. Allowing our pump to out perform any competitors pump using the smaller restrictive 1/4" hose. Essential for our 1200+ horsepower customers who need every bit of their pump.
*Dual 3/8" NPT fittings also allows our tank to be used as a trunk mount 3 gallon reservoir for air to water superchargers. Not just a water methanol tank. Simply remove the plug and you can now run both feed and return lines.
*Dual 3/8" NPT fittings allow the use of a second pump for our extreme applications which require the use of two pumps. Sounds crazy but it happens.
*Custom bent aluminum mounting straps to fit the tank perfectly. Each strap is also machined for a nice brushed look. We could have just bent the straps and called it done but we didn't.
*First trunk mount tank with built in virtual sump with rear pick ups.
*3 Gallons capacity vs competitors 2.5 gallon
*Pump reversed under the tank for a clean, stealth appearance above. First and only of it's kind.
Jan 12, 2016 12:01 AM
OrangeCoba
Oct 1, 2015 10:00 PM
nathan112i
Sep 30, 2015 07:12 PM
Sep 27, 2015 08:53 PM
