All Cars Café The landing pad for automotive discussions, news, articles, and opinions. A place for the community to kick back and chat about all cars.
EXNINJA's kit car build thread
Old 04-29-2019, 02:38 AM
  #251
Sharkey's Avatar
yea gotta go easy on those small nut-serts, ive broken a mandrel myself.
its looking good. keep it up.
exninja (04-29-2019)
Old 04-29-2019, 08:31 AM
  #252
jdbaugh1's Avatar
My experience with rivet nut inserts did not leave me impressed. The worst is when they don't grab enough to keep from spinning but you don't find out until a bolt is all the way threaded in but then you can't remove the bolt because the nut insert just keeps spinning without a good way to grip it with anything. They are handy when they work right though.
Old 04-29-2019, 09:34 AM
  #253
exninja's Avatar
Yeah, I haven't torqued any high enough to find out. I've mostly used them instead of rivets or in lightly-loaded areas like this. I have heard spinning is a problem.
Old 04-29-2019, 10:59 AM
  #254
steelmesh's Avatar
Possibly this detail is overlooked: you need to set the tension for how much it deforms the rivnut, if you're slipping nuts than you need to smash it more. I will smash a few rivnuts in the air to make sure the setting is right, you can see how hard the lips are crushing together. For example, last week I used rivnuts on a composite trunk tray, like a thin fiber reinforced plastic, I had to back off tension all the way and even loosen the rivnut on the mandrel to prevent over smashing the lips together because plastic. When I rivnut them i the air, I can see an air gap between the deformed rivnut, so that means tension is greatly reduced.
Old 04-29-2019, 12:31 PM
  #255
Sharkey's Avatar
also, make sure yous using good nut serts. i avoid the aluminum ones completely. with the steel ones ive got some in bulk before that dont have the spline on the outside to bite into the material to keep them from spinning, and well, they always end up spinning. i have a hard time getting them in bulk where i am anyways, so i usually get the Pop brand (red and white package), and i have the least troubles with them.
Old 04-29-2019, 01:01 PM
  #256
exninja's Avatar
ew, yes, i haven't gotten aluminum ones and they've had the splines/knurling.
Old 04-29-2019, 01:15 PM
  #257
steelmesh's Avatar
Like zo:
Amazon Amazon
Old 04-30-2019, 01:22 PM
  #258
steelmesh's Avatar
I played around with a 1/4-20 rivet nut, I riveted one with maximum force and the other was the reduced force setting for the composite material.
exninja (05-13-2019)
Old 04-30-2019, 01:31 PM
  #259
exninja's Avatar
What installer are you using? My arms aren't well calibrated, but I could back the rivet off to a set distance. I would just need to make sure I have enough thread engagement. As it is, I only squeeze the handles about halfway till the nut bottoms out (on the blind side). When I kept pushing is when i broke the mandrel.
I mostly finished my box and lid last night. I just need to trim a couple of holes in the lid so that I can remove the lid without removing all of the fasteners on one side of the box. I'll take pictures when I do that, the lid alone is pretty boring.
Old 04-30-2019, 01:48 PM
  #260
jdbaugh1's Avatar
The setter I used was an air powered unit that threaded into the rivet nut which tightened it against an serrated head which prevented the nut body from rotating and crushed the rivet body that way. Only thing i could adjust was air pressure and I gave it everything my garage compressor could muster. 1 out of 6 spun when I tightened the bolt.
Old 04-30-2019, 02:17 PM
  #261
steelmesh's Avatar
I got this kit:
Amazon Amazon
With this particular tool you can adjust it so that when the handles are fully stroked, it will pull the mandrel inwards a certain distance, deforming the rivnut a certain amount.
Old 04-30-2019, 02:57 PM
  #262
exninja's Avatar
Originally Posted by steelmesh
I got this kit: https://www.amazon.com/Astro-Pneumat...E73MZYBNQ93ACJ
Mine is the Tacklife version of basically the same thing.
Old 04-30-2019, 04:45 PM
  #263
steelmesh's Avatar
Screw in (righty-tighty) detail pointed out by Blue arrow for less crush [deformation] of the rivnut when doing a full stroke of the handles. Red arrow is locknut. If still too much crush, don't screw rivnut onto the mandrel all the way to reduce crush; as in don't bottom out the threaded insert when screwing onto tool.
exninja (04-30-2019)
Old 05-01-2019, 06:58 PM
  #264
exninja's Avatar
As promised, pictures of the completed electrical box. I also connected the rear end to the frame. Next is the front end, then I'll make an exhaust.
Old 05-02-2019, 12:26 PM
  #265
exninja's Avatar
Mated the front subframe. I checked clearances and determined for certain I'm doing a side exit exhaust rather than routing the exhaust under the transmission.
Old 05-11-2019, 12:29 PM
  #266
exninja's Avatar
Managed to bolt in the driver's seat with a slider. It's actually quite tricky. Then I let the boys sit in it. They approve.
Snail_SS (05-11-2019)
Old 05-15-2019, 04:40 AM
  #267
LSX RWD S/C conversion
victory_red_SS's Avatar
This is so cool, I look forward to seeing more pictures/information as you continue to move forward.
exninja (05-15-2019)
Old 05-15-2019, 08:18 AM
  #268
jdbaugh1's Avatar
Are your boys into cars or going fast yet?
Old 05-15-2019, 02:05 PM
  #269
exninja's Avatar
Kind of. The younger one has always liked going fast. The older one is more apprehensive. They think speeding is bad so when they think I'm going over the speed limit they'll tell me. Must've been their mom that taught them that. Or when I accelerate they think I'm going too fast.
Old 05-17-2019, 02:01 AM
  #270
exninja's Avatar
Made some progress on the wiring tonight. Got the battery cable onto the starter, and a thick wire from there up to my electrical box. Cut some cable to go between the alternator and starter, but I need to crimp an eyelet onto one end of that. Laid out what I want to do in the electrical box. Reconnected all of the engine harness to see what I need to adjust. Looks like the only wires I need to lengthen are the alternator wires.
Old 05-17-2019, 09:32 AM
  #271
Kolt's Avatar
Looking good, like how everything is getting layed out in the same area and easily accessible. Wish gm would do stuff like that
exninja (05-17-2019)
Old 05-17-2019, 10:12 AM
  #272
ProfDNS's Avatar
Looking good ex!
Old 05-17-2019, 01:50 PM
  #273
exninja's Avatar
Right? Thanks for the help, BTW. Most people doing this kit leave the Miata harness untouched so it ends up being a huge rats nest in their box (if they have one). I really think it's time well spent to just clean it up and build your own circuits.
Old 05-17-2019, 04:17 PM
  #274
Kolt's Avatar
No problem, that sounds like a nightmare. All that work just to skimp out on wiring.
Old 05-19-2019, 12:12 PM
  #275
exninja's Avatar
Took it easy yesterday. Did some shopping and did a "flasher mod." It consists of replacing a resistor in the flasher module so that it doesn't "hyperblink" when you use LEDs. The side effect is that it never hyperblinks, but I'm not worried about that, especially with LEDs.
Quick Reply: EXNINJA's kit car build thread
