55w HIDs in gen 3 projectors.
Old Apr 6, 2011 | 10:10 PM
russell10x's Avatar
so something got messed somewhere along the line and i got two 55w h1 kits for my projectors when i wanted 35's.
so the question is can i or cant i and why.
thanks
Justin
Old Apr 6, 2011 | 10:15 PM
TommyP's Avatar
AWD > FWD
You can. Go for it.
Old Apr 6, 2011 | 10:22 PM
russell10x's Avatar
really? the headlights say on them no HID. and i've read in places to only put in 35w kits because of heat and all that bs. but as long as they dont do short term damage i dont care, they will probably be in a dump in a year or two anyway.
Old Apr 6, 2011 | 10:23 PM
thedude411's Avatar
The 55w will wash a bit of color out if your bulbs. Like if u have 6000k bulbs they will look like 4500-5000k. But they will be brighter
Old Apr 7, 2011 | 08:22 AM
Hammbones's Avatar
If you want the 6k temp range, get 8k bulbs with 55w -- It will kick it back to around 6100-6500 color / temp range. Just make sure your setup can handle the heat.
Old Apr 7, 2011 | 08:40 AM
TommyP's Avatar
AWD > FWD
You should be ok. I meant they would physically work, for how long idk, the heat may burn the reflector bowl in the projectors, but idk. I'm not entirely sure if anyone's done it before. I would just wait and send them back if you're worried about it.
Old Apr 7, 2011 | 08:42 AM
kikal8's Avatar
haha first of all. the wiring will melt eventually if u use them. the bulbs and or ballasts will blow pretty quickly. i wouldnt. especially if uhave the opportunity to take em back. get the right ones.
Old Apr 7, 2011 | 10:04 PM
BooSSted's Avatar
DOOO ITTTT.........But let us know how it works before we do it! haha
Old Apr 11, 2011 | 03:28 PM
russell10x's Avatar
why will my wiring melt? and how would my bulbs or ballasts blow quickly? its no different then running a 55w kit in stock headlights which i done for awhile. my question was can the headlights handle it. which i realize they probably wont, because there not designed for it, but its not like both high and low is going to be running the same time. but anyway they'll be here in another two days. the option to send them back is there im sure but its going to cost me the shipping. i dont know what i will do yet. depends on my mood on wednesday.
Old Apr 11, 2011 | 03:41 PM
TommyP's Avatar
AWD > FWD
As long as you run a relay harness, you're wiring will be fine. Running your hid kit at 55w cuts your bulb life in half. It wears them out quickly. The ballasts may be made to handle 55w, but the bulbs are not.
Old May 5, 2011 | 10:48 PM
russell10x's Avatar
everythings all perfect! i ran them for a full month now with no relay harnesses with absolutly no issues, no wire melt or anything! the only problem was with high beams on for too long then switch back to low you can't see anything...at all. so i bought a relay harness for each kit and installed today. next is to relay them together. but to any haters or disbelievers, its done with no problems at all!
Old May 5, 2011 | 10:52 PM
09PitchBlackSS's Avatar
Haters? No one hating just people giving advice. Also the bulb life will be shortened, 1 month is not enough time to tell.
Old May 8, 2011 | 09:09 PM
russell10x's Avatar
ok so what if bulb life will be shortened? bulbs are 20 bucks. otherwise, i asked what it would do to the headlights and no one could tell me because it seems no one had done it. well if anything happens for the worse ill let you guys know.
Old May 8, 2011 | 11:50 PM
shadowfaxss's Avatar
I have run 55 watts for 6 weeks before I took the Gen1s out for winter on the stock harness. Some advice, look at the ground connections on your engine and on the chassis in the front.....they become very corroded (at least in PA during the winter). I cleaned mine and covered the connection with di-electic grease.
Old May 9, 2011 | 10:59 AM
slapbetcommissioner's Avatar
The wire damage won't occur short term. The extra heat added over time will not "melt" the wiring but more likely make it brittle and when it gets cold or bounced around allot it will crack and short out.
Old May 9, 2011 | 12:20 PM
Cold in Winnipeg = frigid
Old May 9, 2011 | 12:42 PM
If that was a shot, it was un called for. Only helping. Hate to see someone ruin there wiring harness without all the facts.
If you wish to run 55 watt ballast just make sure you use s relay.
Bulb life is shortened but not a big deal if you expect it.
Old May 9, 2011 | 10:10 PM
russell10x's Avatar
i think us canadians get made enough fun of for having cold weather. haha. bulb life is no issue at all. and i have a relay harness on each kit. as for the gen 3's, if they $%#k up from them ill throw them away and sell the hid kits. its not the end of the world. i dont think so anyway...its not 2012 yet is it?
Old May 10, 2011 | 09:42 AM
Actually....it was not a shot. I did an assignment there for six months and loved it. Just stating the facts. What is cold to us is absolutely frigid in comparison. The only thing I hated about being there was the temp and the constant wind.
So no poking or making fun of anyone here.....not my forte.
chefhhr
Oct 26, 2015 10:36 PM
allpro666
Oct 6, 2015 08:11 PM
dieGone
Sep 23, 2015 10:20 AM
