about ark antenna
theoretically there will be lost signal, its physically impossible to not loose any, maybe its just that the signal in ur area is so strong that you didnt notice the signal lost.
So far I haven't lost any stations. But I live in Myrtle Beach so the station signals here are pretty strong. If you're in a rural area I would guess you would lose some stations. Depends on signal strength. It looks great though!
04-06 Chevy Cobalt ARK Short Antenna (Black)
Material: AL 6061 - CNC Aluminum
Color: Black / UV coating Coated
Fitting: Same as OEM fitting 6mm bolt only
Using this Antenna you can get rid of your over-sized factory antenna - Special look on your ride
Later model 2006 cobalt, must check thread size.
Only for 6mm Female bolt pattern
check your bolt fitting before place order.
Apperance use only- Perfect fitting no adapter need
ARK decal included
If you have other information share it with everyone!
ARK decal included
I have a Cavy... I just cut the ball off the stock antenna and stuck it back on there. I have listened to the radio for a total of about 30 seconds since I got my car 8 months ago; I'd remove the whole antenna assembly if I could.
You got the only ark antenna with a 7MM thread or your 07 is the one factory Cobalt that still had the 06MM thread. Post the Part number of your ark antenna and measure your thread.
I didn't write the data in my post -- I copied it from the website.
Here is another 07 Balt with 7mm thread with an ARK antenna!!!!
