? about CF trunk
Old Aug 5, 2007 | 12:26 PM
tim0shel's Avatar
? about CF trunk
Guys that have put on CF trunks on there cars, did you leave the gas supports on that help lift the trunk up when open?
I didn't know if it would be too much pressure on it when closed since they are strong enough for the OEM trunk and the CF is much lighter.
Also how can you adjust the rear closes to the window back down some it sticks up above the car a little bit. And i have already turned the screw all the way down thats on the hinge part.
Thanks,
Old Aug 5, 2007 | 02:36 PM
biohazard's Avatar
Get low
Thanks,
i kept the gas shockls on its fine..... here is a trick to ghet rid of your trunk still looking open when u shut it.... i messed with the hinges for hours, even elongated the hing holes and brought the hinger down further..... but here is the best thing to do.... the little latch in the deck lid with the 2 screws in it..... put the screw through the deck lid then add some shims(washers) then screw into the latch.... this brings the latch further up into the trunk pulling the trunk down further when u shut it... i have about 3 washers on each screw
Old Aug 5, 2007 | 03:53 PM
PlaysWitCars's Avatar
Former Cobalt Owner
Hmmmmmmm might have to try them to see if i cant get mine to come down a tad more
Old Aug 5, 2007 | 04:46 PM
tim0shel's Avatar
Thanks for your help i will put my gas shocks back on.
I didn't completely understand about pulling the lid down..
The latch i have has 3 screws in it and attached to the lock so it doesn't move too much. You put the shims on the inside where the latch mounts to the lid correct. And then put the screws in and tighten down. I think i understand correctly. I had a hard time with the lock clip in think i have it on enough.
Heres pic of it on.
Old Aug 5, 2007 | 04:53 PM
KlutchSS's Avatar
my question is where did you buy the CF trunk that still has the lights.
Old Aug 5, 2007 | 05:05 PM
tim0shel's Avatar
Still has the lights? Thought they all had the lights in them. Of course you have to put them in. I bought it from Pet on here he had the trunk and hood.
Hopefully the hood will be here soon and i will have it on soon.
Old Aug 5, 2007 | 10:02 PM
biohazard's Avatar
Get low
o gotcha see i dont have the lock anymore (or 3rd brake light) so the lock wasnt a prob for me when moving the latch up further into the trunk
Old Aug 5, 2007 | 10:04 PM
KlutchSS's Avatar
i want to know where to get that trunk from.
Old Aug 6, 2007 | 01:26 AM
ThatGuyinApt.D's Avatar
http://www.cobalt-addiction.com/exterior.htm
i dont even have a balt and i figured it out.
Old Aug 6, 2007 | 05:13 PM
tim0shel's Avatar
lol^^^^
i think i have figured it all out. i will post later on what i did.
Old Aug 6, 2007 | 05:17 PM
Rangerondubz's Avatar
Owned
Old Aug 6, 2007 | 06:22 PM
bas2k4's Avatar
Damn tim0shel that trunk looks great man. Now get the cf wing insert and it will be even hotter.
Old Aug 6, 2007 | 07:48 PM
tim0shel's Avatar
Thanks bas2k4, That brings up a question i have had. The center wing insert i have heard of some cracking and so on. How often has this happen? I don't want to buy one and down the road it cracks and has to put the OEM back on.
And far as aligning the trunk i have found that you can move the hinge as a whole up, down, front to back, also of course the part of the hinge that the trunk connects to. The piece that the latch connects to also can be fine adjusted for lining up the gaps on either left to right.
Old Aug 7, 2007 | 03:15 PM
biohazard's Avatar
Get low
ya thats wut i did it just wasnt enough for me, trunk still looked open lol
Old Aug 7, 2007 | 07:48 PM
tim0shel's Avatar
Yea still not completely happy with it but i have got it durn close and afraid that if i keep fooling with it i will end up making it worse and have to keep on messing with its.
camaromanss1992
Oct 1, 2015 10:51 PM
royce777
Sep 28, 2015 07:11 AM
grampss
Sep 27, 2015 08:51 PM
c_m_shooter
Sep 27, 2015 04:40 PM
CobaltSS 16
Sep 6, 2015 02:04 PM
