adding fog lights
Old Feb 21, 2012 | 10:49 PM
drumrush's Avatar
adding fog lights
I've got an ss bumper on the way, and need some fog lights. Is this the wiring harness I need?
COBALT CORVETTE GM WIRING HARNESS 2008 ENDS OTHERS | eBay
And then all I would need is the actual fogs and the switch? I've done a bunch of searching and haven't found anything helpful
Old Feb 21, 2012 | 11:07 PM
Validater's Avatar
What I'm gonna try is to tear apart the under hood fuse block. find the Fog fuse and or relay, run the wire. Connect an OEM switch to the already supplied wire that is in the dash, and have the dealer program the BCM for fog lights. I've searched AllData, and it shows that the BCM controls it and then the signal goes to the under hood fuse box.
Hope that helps.
Old Feb 21, 2012 | 11:10 PM
drumrush's Avatar
My dealership charges over 100 to reprogram the bcm. ****
Old Feb 21, 2012 | 11:18 PM
Validater's Avatar
Yeah they did that for me too when I had them program in Cruise control. but they charged an extra .5 cause they decided to call the engineers and see if it was even possible.
I screwed up and didn't print out the step by step that was in the how to here. Talked to the manager and he had it done the next day without even asking me how too cause he already knew. FML
Old Feb 21, 2012 | 11:24 PM
znew's Avatar
I have mine wired into the parking lights so i can control the fogs and run them without the headlights, i just bought 15 dollar wiring harnesses off ebay
Old Feb 21, 2012 | 11:26 PM
drumrush's Avatar
I want a separate control for the fogs. But I dont know the easiest way
Old Feb 21, 2012 | 11:27 PM
1LowLS's Avatar
The fogs I ordered came with a hrness,relay and aftermarket fog button and I also added another relay for them to have them automatically come on with the headlights.So I can turn the fogs on by themselves or leave em alone and they will come on with the headlights.I can post a vid of it if you want
Old Feb 21, 2012 | 11:31 PM
drumrush's Avatar
Where'd you order them from? I just ordered fogs a few mins ago. They are only the lights, but were 50 shipped
Old Feb 21, 2012 | 11:34 PM
1LowLS's Avatar
Ebay.not sure of seller but they came with bulbs,harness and switch.
Old Feb 21, 2012 | 11:35 PM
drumrush's Avatar
Wow
Old Feb 21, 2012 | 11:38 PM
1LowLS's Avatar
Here check this out.
Cobalt LS HID foglight - YouTube
Old Feb 21, 2012 | 11:43 PM
drumrush's Avatar
Where'd you get the relays? I really only want the one hooked to the switch. I dont want my fogs on with the low beams all the time
Old Feb 21, 2012 | 11:49 PM
1LowLS's Avatar
it came with the fog assemblies.it was the fogs,bulbs,relay with full harness and button,all prewired.All you have to do is connect it to power and ground and run the wires and your good to go
Old Feb 21, 2012 | 11:51 PM
drumrush's Avatar
How much did you pay? And if you can remember the seller please let me know
Old Feb 21, 2012 | 11:54 PM
1LowLS's Avatar
I think they were only $50 fack I can't remember lol.let me search hold on
Old Feb 22, 2012 | 12:03 AM
heinen02's Avatar
I would put HID's in the fogs and then just run a Wire from your fuse box pulling off a fuse that loses power when you shut the car off to a switch then down to the HID Relay. This would allow you to turn them on and off and have them on with both low and high beams.
Old Feb 22, 2012 | 12:07 AM
1LowLS's Avatar
This is the same harness that was sent with mine
H11 BULBS FOG LIGHT WIRING WIRE HARNESS KIT W/RELAY & SWITCH KIT | eBay
Old Feb 22, 2012 | 12:09 AM
1LowLS's Avatar
With how I have my 2nd relay wired,I can have the fogs on with low beam,high beam,running light+fogs,no light+fogs,or car completely off +fogs.
Old Feb 22, 2012 | 12:21 AM
heinen02's Avatar
Damn, thats alot of options haha. I just would be worried about forgetting about them being on if they where hooked up to a constant power feed.
I guess i dont know exactly how you have yours wired so im sure you prob dont have that issue though.
Old Feb 22, 2012 | 12:24 AM
1LowLS's Avatar
that's what the led button is for.Watch my vid and you will see. And you can always hook the trigger source to a switched circuit.
Old Feb 22, 2012 | 12:35 AM
heinen02's Avatar
Fail on my part for not watching video. I will say though i do like your set up that you have going. alot better then what i had suggested.
Old Feb 22, 2012 | 12:37 AM
1LowLS's Avatar
Thanks.It works well for me.That way if I forget to turn them on with the button,They will turn themselves on with the headlights.
Old Feb 22, 2012 | 08:47 AM
taerae86's Avatar
mine are like this too...i got the lights with pigtails from Morad on ebay, wired them myself and used my own switch...
Old Feb 22, 2012 | 11:22 AM
1LowLS's Avatar
Nice!luckily mine came with a digital led button
Old Feb 22, 2012 | 11:25 AM
breds2k's Avatar
aw man, i shouldve commented last night, I was going to suggest mounting TRS Blazer fogs to the bumper rather than going oem I BELIEVE the are the same size, and the blazers are very similar projectors but with a deeper housing and a clear lense that will be 10x better than factory SS fogs. And they are only $50 at TRS.
RaginChopsuey
Oct 27, 2015 01:27 PM
brandon04
Oct 21, 2015 07:04 AM
dennis69
Oct 20, 2015 04:49 PM
z28addiction
Sep 28, 2015 12:03 AM
