Adjust fog lights
Old Jul 30, 2008 | 09:40 PM
crt013189's Avatar
Adjust fog lights
Hey I was wondering if there was a way to adjust the fog lights in an 07 ss/sc the reason is is because I installed HID in the fogs and the passenger side is pointed more towards the ground than the drivers side and I just want to make them the same and level is there a way to do that thanks
Old Jul 30, 2008 | 09:42 PM
BLAZIN07SS's Avatar
I'm too JDM for you
make sure you bulb is still in correctly. this same thing happened to me and it was because the bulb wasnt in all the way
hatrickstu's Avatar
lay on the ground look up at the top of the light from in front of the car. you will see an allen head bolt. that is it
Old Jul 30, 2008 | 09:56 PM
crt013189's Avatar
Im assuming i have to take off the black molding to get to it
ill double check the bulb but im pretty sure its in all the way
Old Jul 30, 2008 | 09:59 PM
ItalianJoe1's Avatar
No, you can get to the adjuster from the front of the car, its just over the lens.
Old Jul 30, 2008 | 10:02 PM
crt013189's Avatar
through the little hole at the top of the fog light
Old Jul 30, 2008 | 10:12 PM
hatrickstu's Avatar
yep!
Old Jul 30, 2008 | 11:23 PM
crt013189's Avatar
yep!
thanks im going to go adjust them now
ok i tried adjusting them and it still did not solve the problem i get this
ive spent over an hour trying to figure out what the problem is also it seems that one bulb is brighter than the other one its not the fog because i switched them up so im not sure what the problem is can anyone help.
Old Jul 30, 2008 | 11:34 PM
hatrickstu's Avatar
sure its in there correct?
Old Jul 30, 2008 | 11:41 PM
crt013189's Avatar
im almost 100% sure i have taken them out on both sides and put them back in i have no light leaking through around the fog and the bulb i have no clue whats wrong
Old Jul 30, 2008 | 11:47 PM
hatrickstu's Avatar
you didnt accidentally move the cutoff plate in the lense did you?
Old Jul 30, 2008 | 11:48 PM
crt013189's Avatar
where is that at i have no idea i just took the old bulb out and put the new HID bulb in
Old Jul 30, 2008 | 11:49 PM
hatrickstu's Avatar
take the bulb back out, look inside the actual lense, make sure the metal light block off plate is still level
Old Jul 30, 2008 | 11:53 PM
crt013189's Avatar
i would have to take the entire fog assembly out of the car to do that i assume
Old Jul 30, 2008 | 11:55 PM
hatrickstu's Avatar
yep.
Old Jul 31, 2008 | 12:20 AM
crt013189's Avatar
yep.
ok and doing that i will have to go from the bottom of the car i would guess and i have one more question would the metal cutoff thing also cause one light to be brighter than the other
Old Jul 31, 2008 | 12:28 AM
hatrickstu's Avatar
no it would not
RaginChopsuey
Oct 27, 2015 01:27 PM
dennis69
Oct 20, 2015 04:49 PM
justinchinn
Oct 2, 2015 12:18 PM
z28addiction
Sep 28, 2015 12:03 AM
