Air buubles on Decal?
Old Jan 12, 2006 | 04:10 PM
Nickc84's Avatar
How do you get rid of air bubbles on a Decal? I did everything right ....It looks fine from a far but if u look close it looks bubbly in spots
Thanx
Old Jan 12, 2006 | 04:12 PM
GSoccer24's Avatar
If its a vinyl decal take an x-acto knife with a fresh blade and give it a quick tiny poke while pushing the air out of the hole you poke with a finger
Old Jan 12, 2006 | 04:31 PM
R33P3R007's Avatar
360 L337 User
start over if you want it to look good. but if you do it right what Gsoccer said will actually work
Old Jan 12, 2006 | 04:37 PM
GSoccer24's Avatar
yeah you could start over and you might want to wet apply it with a squeegee so you have some time to play with the positioning and have a better chance of getting more bubbles out than just laying it dry
Old Jan 12, 2006 | 05:20 PM
Nickc84's Avatar
**** well i cant start over i took the clear part off I thought once i layed it down the acutaly decal would ripp off
Ill get a pic soon to get opnions of its bad ill remove it
Old Jan 12, 2006 | 06:01 PM
LSpower05's Avatar
You can use the x-acto knife, or if it's just a few small bubbles then just give it some time. The sun will make it go away in time. Mine did anyway.
Old Jan 12, 2006 | 06:19 PM
GSoccer24's Avatar
^^^he's right too they eventually do go away in the sun
Old Jan 12, 2006 | 06:33 PM
BowTieCobaltSSSC's Avatar
You can also use a hair dryer to shrink it . But not to close or to fast .
Old Jan 12, 2006 | 07:35 PM
badg1rl's Avatar
i heard about the hair dryer thing...and it does work from what i have heard
Old Jan 12, 2006 | 07:37 PM
GSoccer24's Avatar
^^^it does but too much is bad because most of those shrink a ton when heat is applied, and if one part shrinks while the other sticks, they can actually tear.
just gotta be real careful and use the heat in quick bursts for the desired outcome
Old Jan 12, 2006 | 07:42 PM
Dman's Avatar
i used to heat then push it out
Old Jan 12, 2006 | 07:49 PM
GSoccer24's Avatar
^^^sounds painful
Old Jan 12, 2006 | 08:03 PM
Dman's Avatar
muahahaha, thats horrible...
no_ss
Oct 18, 2015 11:58 PM
z28addiction
Sep 28, 2015 12:03 AM
grampss
Sep 27, 2015 08:51 PM
DocSvensk
Sep 27, 2015 02:24 PM
OrangeCoba
Sep 25, 2015 06:06 PM
