Antenna Problems
Old Apr 27, 2011 | 04:49 PM
09Sp0rt's Avatar
Antenna Problems
I am trying to twist off my stock antenna to install my shorty, but the stock one just keeps twisting and never come off... how the hell do I get it off
Old Apr 27, 2011 | 04:52 PM
Supercharged Guy's Avatar
Becareful so you don't keep twisting cause it eventually could snap it off, I learned the hard way when I did mine on my 06
That's weird that it won't just come off
Try some wd40 or something, it could be bound up on one of the threads
Old Apr 27, 2011 | 04:53 PM
BPacak's Avatar
Vtec Rep
hold it from the inside of your truck with plyers or something
trunk*
Old Apr 27, 2011 | 04:54 PM
09Sp0rt's Avatar
Am I spinning the right way? I'm spinning it counter clockwise
Old Apr 27, 2011 | 04:59 PM
O9cobaltSS's Avatar
haha yes
Old Apr 27, 2011 | 05:06 PM
09Sp0rt's Avatar
Alright, and I'm usng a wrench to twist on the black part that's a little thicker than the actual antenna, the piece I'm talking about is like an inch and a half tall
Old Apr 27, 2011 | 05:08 PM
BPacak's Avatar
Vtec Rep
or just ignore what i said lol
Old Apr 27, 2011 | 05:10 PM
09Sp0rt's Avatar
Ok hold what. All I see is a wire
Old Apr 27, 2011 | 05:12 PM
BPacak's Avatar
Vtec Rep
look a little farther, more than a wire.
Old Apr 27, 2011 | 06:12 PM
NCC-2000's Avatar
If it is already just spinning you may have already busted something. Check what the antenna wire plugs into from inside the trunk. Is that part spinning too? If it is, you needs a new antenna base.
Old Apr 27, 2011 | 06:53 PM
09Sp0rt's Avatar
Then I guess a need a new antenna base how might I go about getting a new one?
Old Apr 27, 2011 | 06:56 PM
reefone's Avatar
lefty loosey, righty tighty.
Old Apr 28, 2011 | 12:46 AM
NCC-2000's Avatar
Well look in the trunk and confirm that the base is in fact broken. It bolts up to a tab in there to keep it straight and immobile. If something did snap, check which it was, the base itself or that bracket that it bolts to. Getting a new base is easy, replacing that bracket, that's hard.
turbochargedss2012
Sep 20, 2023 12:17 PM
yellow dragon
Sep 28, 2015 09:49 PM
Iceberg
Sep 28, 2015 01:31 PM
DocSvensk
Sep 27, 2015 02:24 PM
Adiaz1ss
Sep 26, 2015 11:51 PM
