best method to remove light nightshading
Old May 1, 2009 | 05:47 PM
Zdeuce4's Avatar
wut do u guys think the best method to remove nightshade off is? i have one that is peeling and id like to redo it and clear it this time. i didnt clear the first time.
Old May 1, 2009 | 05:49 PM
Gestapo007's Avatar
i wet sanded till it was gone then resprayed and cleared when i redid mine
Old May 1, 2009 | 05:51 PM
Wolf117's Avatar
probably paint remover and wet sanding? i think
Old May 1, 2009 | 06:09 PM
Dimitri Manesis's Avatar
Make sure to use a good etch primer if you get it to the bare metal. I like SEM rattle can stuff, it's a little pricey but really works well.
Old May 1, 2009 | 06:14 PM
Steven Flit's Avatar
Acetone works great at removing VHT Night Shade.
Make sure to wet sand after applying acetone, as it discolors the plastic a tad until re-cleared.
Old May 1, 2009 | 06:19 PM
Shibito's Avatar
lacquer thinner + elbow grease
Old May 1, 2009 | 07:51 PM
Zdeuce4's Avatar
wut grit is good for wetsanding? And can u use the same grit in between coats and also when clearing?>
Old May 1, 2009 | 10:45 PM
liljone's Avatar
6k grit
Old May 1, 2009 | 10:48 PM
G5King's Avatar
If you get to the bare metal you probably sanded a little too much of the tail light.
I've heard brake fluid takes it off. Acetone seems to be the way to go though.
Old May 1, 2009 | 10:50 PM
exiged's Avatar
acetone seems a little harsh . . . i would go with lacquer thinner
Old May 2, 2009 | 01:30 AM
Gestapo007's Avatar
yea paint thinner should work fine. But just go find some wet sandpaper, and feel it for one thats a little bit rough and one that feels like paper, like such a high grit you can barely feel it. Then start with the coarser one, then the smooth one, then paint.
RaginChopsuey
Oct 27, 2015 01:27 PM
brandon04
Oct 21, 2015 07:04 AM
dennis69
Oct 20, 2015 04:49 PM
z28addiction
Sep 28, 2015 12:03 AM
