Bolt behind Chevy badge?
Old Jul 1, 2008 | 01:01 PM
CobaltVenomSS's Avatar
what size bolt is holding on the chevy badge on the front of the car??? i need to take it off so i can put my impala SS badge on
Old Jul 1, 2008 | 01:02 PM
lewisb13's Avatar
From: Home: Utica, MI Current Location: Mobile, Alabama
Theres 2 and they are 10mm NUTS.
Old Jul 1, 2008 | 01:03 PM
invisible's Avatar
Yes and cheap ones at that.
Old Jul 1, 2008 | 01:04 PM
lewisb13's Avatar
Plastic bullshit is what they are. Same ones that hold on your reverse lights.
Old Jul 1, 2008 | 01:06 PM
thanks 4 quick responses guys
Old Jul 1, 2008 | 01:14 PM
NCC-2000's Avatar
I've never understood why every other badge on the car can be a simple stick-on thing yet this one has to be held on with nuts.
Old Jul 1, 2008 | 01:28 PM
i cant get the nuts off for anything
Old Jul 1, 2008 | 01:31 PM
lewisb13's Avatar
Pull out on the badge. Like pull on the badge in the direction away from the car while trying to loosen the nuts, you have to catch on the first thread. Get what I mean?
Old Jul 1, 2008 | 05:44 PM
i could only get one bolt off!!!! ill see if my friend can get the other
Old Jul 1, 2008 | 05:47 PM
lewisb13's Avatar
Old Jul 1, 2008 | 05:49 PM
jboll's Avatar
I was able to get my nutz OFF !
Old Jul 1, 2008 | 05:50 PM
i got the one on the right easily off but the left one wont come off for anything
Old Jul 1, 2008 | 05:56 PM
jboll's Avatar
Just be carefull or you will end up twisting that locator with the nut still on it and then you will be Fooked !
That's what I did, you are just spinning the nut around the locator. With the one side off try to pull ( GENTLY ) out away from the car as you try to loosen the other side. Just don't pull to hard or it will break. It's probably about the cheapest thing on the car.
forced_induction's Avatar
be careful they are real cheap, so if you need to reuse them be gentle
DarrenGC
Dec 24, 2021 01:55 PM
SSLOW06
Oct 1, 2015 07:21 PM
dieGone
Oct 1, 2015 06:27 PM
Tupp
Sep 30, 2015 08:18 PM
