bowtie cracked...HELP!
Old Jun 17, 2009 | 06:58 PM
BLACK2007LS's Avatar
currently painting my bowtie black, but when i was taking it off, it cracked and broke in two pieces. i appoxied it back together and it is now one piece. it also had a smooth surface (one piece was not higher than the other). i began to paint, thinking that the paint would cover the evidence of the crack, but i was wrong. ive done 4 coats or so and when its fresh sprayed the crack goes away, but when it drys you can kind of see it. will this eventually go away with more coats and clear coat? anyone else had this issue?
i may have to order a new piece : ( anyone know how much they cost?
Old Jun 17, 2009 | 08:46 PM
haymakercobalt's Avatar
You could probably put enough coats of paint on to cover the crack, but it might be easier to just buy a new one and start over.
Old Jun 17, 2009 | 11:53 PM
well, i did enough coats and i cant see the crack now, im now doing clear coating...probably wont be on my car until friday or so. i just hope i dont crack it by pushing on it when i glue it back on. ALSO DOES ANYONE KNOW HOW LONG I NEED TO WAIT BEFORE EXPOSING IT TO WATER/SOAP/WAX?
also would it be a good idea to put adhesive all over the back to strengthen it before putting it back on the grille?
Old Jun 17, 2009 | 11:55 PM
wardzach2007's Avatar
read the back of the paint can.
You can answer most of your questions from there.
Old Jun 18, 2009 | 12:16 AM
MyCobaltGetsMeCooter's Avatar
same thing happend to mine. Im going to go buy some of that clay/bondo stuff to put over it. sand it down and repaint. and dont use gorilla glue. that **** swells up and leaks out the sides and completely ruins it.
Old Jun 18, 2009 | 12:24 AM
exiged's Avatar
epoxy. sand. paint. clear. done.
Old Jun 18, 2009 | 12:26 AM
i just bought auto appoxy...i think i found it at walmart last night; im also using it to glue back on the grille
Old Jun 18, 2009 | 12:50 AM
benjirman's Avatar
If you epoxy it on there you will NEVER get it off again. Epoxy is binary plastic, a resin and a hardener, so if you use it to reattach your bowtie it will be beyond glued on. I'd use something closer to the factory adhesive. Auto stores should have something that is strong enough but not quite so permanent, just my 0.02.
Old Jun 18, 2009 | 01:00 AM
i didnt mean appox...lol i did mean adhesive haha
Old Jun 18, 2009 | 08:40 AM
guys my clearcoat is real milky...the paint can said it would be like this for 24 hours, its really really milky though, maybe it put too thick of coats on? anyone else have this and then have it fade?
Old Jun 18, 2009 | 11:44 AM
exiged's Avatar
as for the epoxy, i thought the bowtie itself was damaged, i didn't mean to use it to re-attach it to the car. Also, sounds like you sprayed to much clear to quickly.
Old Jun 18, 2009 | 11:45 AM
yeah, im probably going to sand it down and re-do it : ( the black looked really good until i put clear on, maybe i wont use clear? i couldnt picture it coming off
Joe09
Sep 18, 2015 09:22 AM
vred05
How to Guide
28
Mar 5, 2011 12:27 PM
SilverSS/SC
Jul 2, 2007 11:32 PM
watersedge1234
Aug 24, 2006 05:32 PM
CTCOBALTSSS
Jun 14, 2006 12:03 PM
