Clear coat repair
Old Jul 8, 2010 | 07:02 PM
Magz_rule's Avatar
Clear coat repair
So i debadged my car today, all went well until the rear chevy emblem. Sprayed some goo gone on, let it sit for a minute and started taking all the residue off. After getting it all off and wiping the goo gone off, to my dismay the goo gone ate right through my clear coat, now i have a big spot where its dull/swirly and it looks like ****. What can i do? Will a body shop even be able to repair this since it pretty much ate off all the clear coat? FML
Old Jul 8, 2010 | 07:05 PM
hatrickstu's Avatar
goo gone doesnt eat through clear. pics?
Old Jul 8, 2010 | 07:15 PM
Magz_rule's Avatar
heres a pic, btw this is after waxing it.
http://s854.photobucket.com/albums/a...t=IMG_0013.jpg
Old Jul 8, 2010 | 07:16 PM
Gestapo007's Avatar
buff that ****
Old Jul 8, 2010 | 07:18 PM
Phyrric's Avatar
Haha goo gone does eat through clear, the special type made for cars, does not :P
but that sucks lets see some pics of how bad it is, worst comes to worst just covered it back up with the bowtie
Old Jul 8, 2010 | 07:21 PM
Magz_rule's Avatar
linked a pic in third post does it work?
Old Jul 8, 2010 | 07:28 PM
chris88z24's Avatar
Looks like smeared glue.
Use WD-40 and a heat gun (EASY WITH THE HEAT) to remove the glue. If you fucked it up that bad, get some rubbing compound and go to town. Then polish and seal with a wax.
Worst case a bodyshop will have to reclear it.
Old Jul 8, 2010 | 07:32 PM
Phyrric's Avatar
You could also use gasoline or paint thinner and a rag, but you have to be quick about it haha, don't let it sit on there long and wash the back of the car right after it, its what I did
Old Jul 8, 2010 | 07:40 PM
bbrewbaker's Avatar
I had the samething when I took my back on off. It's the glue.
I used combo of rubbing alcohol and NON-Actone nail polish remover.
It took awhile but i was able get it all off.
Then after it is all off you can buff it and your never know it was there.
Old Jul 8, 2010 | 07:42 PM
Ricer's Avatar
not true.. lacquer thinner will not eat through a catalyzed clearcoat. It looks to me like you used a really rough rag or towel and just scratched the hell out of it.. or you just softened the glue and smeared it all over the place. If it feels sticky at all.. you've still got glue on there.. just need more solvent to remove it. If you scratched it.. just buff it out. Your paint is fine
Old Jul 8, 2010 | 07:43 PM
hatrickstu's Avatar
your paint is fine, just gotta make sure you get the glue off and buff that ****. NOT hand wax it, you cant correct paint the right way that way unless you are wetsanding
Old Jul 8, 2010 | 07:49 PM
Phyrric's Avatar
Meh worked on the foour cars I've done it on so far
Old Jul 8, 2010 | 07:52 PM
Ricer's Avatar
oh it does work.. i was commenting on your "gotta be quick about it" statement.. that part wasn't true.. you don't have to be quick about it and rush to wash it off... fact is it'll be evaporated and gone before you could walk over to get the hose.
Old Jul 8, 2010 | 07:54 PM
BlackARCA06's Avatar
Buff it it'll come out and if its damaged yes a body shop would fix it. That would be a easy fix for a shop.
Magz_rule's Avatar
After a while of wd40 and a hair dryer it looks a little better but overall still looks like **** haha. I think the towel i used scratched it up. Guess ill have to find someone to buff it. But you guys think the clear is fine? Running my hand over it feels way rougher than any other part of the car.
Old Jul 8, 2010 | 07:58 PM
Ricer's Avatar
take the wd40 and lightly wet a SOFT towel (although I suppose the soft part doesn't really matter at this point.. haha).. rub that area.. do you see any color on the rag? if not.. you're fine and just needs to be buffed. If you see color.. yousir.. have found a way to eat through a catalyzed clear.
Old Jul 8, 2010 | 08:19 PM
Gestapo007's Avatar
remove the glue with heat and goo-gone. Then buff the now fuckedup paint with swirls from your towel back to a gloss using an orbital buffer and some swirl remover.
if its this difficult. take it to someone else
Old Jul 8, 2010 | 08:27 PM
Magz_rule's Avatar
No color
Old Jul 9, 2010 | 02:10 AM
SSPainter's Avatar
eraser wheel & wax and tar remover.... then give it a good polish
Old Jul 9, 2010 | 07:24 AM
Gestapo007's Avatar
erasor wheels are amazing, but i doubt people have them lol. wax and grease remover will work wonders but Goo-gone should do the same. just try not to put it on a grease rag and compound your paint with it lol
Sl0wbaltSS
Nov 21, 2018 11:11 PM
Fearedbynone
Apr 14, 2016 03:25 AM
RaginChopsuey
Oct 27, 2015 01:27 PM
SlowSaturn
Sep 28, 2015 11:03 AM
grampss
Sep 27, 2015 08:51 PM
