Clear Side Markers
This Vinyl overlay literally took me like 10 minutes to do. I had some White vinyl laying around in the garage I had no plans on using so here it is in White:
Before:
After:
I'm mixed about the results. It has 0 illumination behind the vinyl. I might end up doing nite shades on it but I don't know exactly....
Before:
After:
Find a shop that does wraps for cars. There is a Perforated vinyl that is meant to go over windows that has a bunch oh holes in it so you can see through it. You see it all the time on bus and train wraps. Have them print it to match your paint. You won't get an exact match because it is cmyk but it should be close enough. Once you put it on it will look opaque but the light should show through the holes. This is not what it is meant for so try testing it first to make sure enough light gets through to give the effect you want.
Wrap Tips - A Site for Digital Sign Graphics and Vehicle Wrap Printing » Getting Started with Signs & Vehicle Wraps Sign Supplies & Vinyl Printing Equipment » Perforated Window Film for Your Vehicle Wraps
DANRICKARD
Oct 1, 2015 12:08 AM
