Cobalt/2007 VW Passat Retrofitted Tail Lights
i'd like to bring this back up.
I'm planning the 0o o0 look for the summer. Anyway pics of how you you went about this? just general, like the rear of the light housing etc? so I can understand how u popped it all together?
I'd like to add something here... if you want to separate the turn signal from the brake you could just splice into the third brake light to get a brake-only signal, splce into your front turn signal wires to get signal-only... through the use of diodes and resistors you can perfectly replicate the Passat. This would look absolutely SICK on a G5 coupe.
havent done it yet so i dont have a clue...i assume it should be easier than cobalt ones cuz theres more grip and leverage as a result of the shape...what are you thinking about doing?? im planning to take mine apart in the near future and painting most of the inside part black to darken it up
i gotta measure the diameter of the chrome circle of the actual taillight under the lens and see what will fit in there
i might even be able to just get a set of cobalt outer taillights and some how retro fit them into the g5 lens...i dont have much experience in ******* around with **** like that esp with wiring so i gotta be careful
It wont be hard at all. Just cook them in the oven at about 200 degrees for 20mins or so and they should just come right apart but be careful so you don't break the outer lens.
The pics look awesome by the way.
