Condensation In New Projector Housings
Old Jun 26, 2008 | 12:54 AM
wardzach2007's Avatar
Okay, so I had a question. I went to the blue wave car wash, and after the 5 minute drive through car wash, I park my car and got out and notice just on my driver side headlight housing there was condensation on less on some of the housing. But after 4-7 minutes it dried up and now everything is back to normal. So my question is:
Will this hurt the housing if I keep on getting moisture in there even if it dries up pretty quickly? The HID bulb is protected by the projector lens anyways.
Last edited by wardzach2007; Jun 26, 2008 at 12:54 AM. Reason: Automerged Doublepost
Old Jun 26, 2008 | 12:56 AM
Mnatvyc1223's Avatar
besides it lookin like crap, i may possibly short out one of your lights over time.
you can bake you headlight open and then re-seal
Old Jun 26, 2008 | 12:57 AM
Did you mean bake or break?
Old Jun 26, 2008 | 02:29 PM
Whitty's Avatar
i can't speak for him but pretty sure he means bake. Like you would do if you are painting the stock lights. In an oven on low low heat for about 10 mins. then scrape all the glue out and re do it with goop or something similar
Old Jun 26, 2008 | 03:02 PM
Kibosh3's Avatar
o man....bawls to that...good luck...
and yes, he meant bake...to take the housing apart and reseal them...on my old first gen projectors i just used window silicon...
havnt touched my CCFL seals and havnt had a problem yet
Old Jun 27, 2008 | 01:44 AM
How long do you leave it in the oven?
Old Jun 27, 2008 | 01:46 AM
REIGN SS's Avatar
Original Hayden Fanatic
150* for 15 minutes
Old Jun 27, 2008 | 01:54 AM
jefferyss's Avatar
you could start by plugging up the 3 or 4 vent holes on the back side...once there sealed you will know if its the vents letting moisture in or if its the seal around the headlight your choice really
Old Jun 28, 2008 | 06:27 PM
kryptonkid07's Avatar
sounds dangerous. haha.
Old Jun 28, 2008 | 06:33 PM
GSMiller's Avatar
One of the stock headlights on my Moms Blazer gets condensation on the inside of it from time to time but is yet to do any damage.
Old Jun 29, 2008 | 09:03 PM
glen229's Avatar
personally id just use a heat gun.. i did that on my old ranger i had the same problem just heat up one area and work your way around it was very easy and i just got some apoxy from homedepot for like 5 bucks that works awsome just make sure to get clear drying apoxy
Old Jun 29, 2008 | 09:09 PM
CRACKERSS's Avatar
I've been haveing the same problem with my stock drivers side head light. Took it out today to make sure all the seals were tight and had about 1/2cup of water inside. Cant see any hole or vent holes in the back. Going to try and reseal it next week.
Solaris99
28
Mar 15, 2017 01:22 PM
Jan 12, 2016 12:01 AM
hacadacalopolis
Oct 28, 2015 06:09 PM
Slick_Nick
Sep 28, 2015 09:15 PM
