Custom Interior/Interior Lighting Thread!
Old Oct 30, 2009 | 08:25 AM
  #51
iboost's Avatar
Originally Posted by LT07
It depends on what red you have... the bright red is called Victory Red (code is 74U), And the darker red is called Sport Red (code is 29U)
I got the duplicolor called "Bright Red"...I don't know what the code is but its labeled on the can.
As for debadging, theres a bunch of how to's on what to do. Different people recommend different things. Its really all up to you
Old Oct 31, 2009 | 10:02 AM
  #52
tombomb's Avatar
Originally Posted by TiggeR
thanks so much!! kudos for u lol, now how about the gauges? lol
haha no prob! and the guages are actually just two leds mounted on the steering column pointed at the guages (had to put electrical tape aroung the leds so that they wouldnt glare and be visible)
edit: if you look close enough you can actually see them in pic 1
Old Oct 31, 2009 | 03:16 PM
  #53
TiggeR's Avatar
so im guessin u had to take apart the whole dash?lol oh geez..and is it just like one single round tip led? or did u have a couple?
Old Nov 3, 2015 | 01:24 PM
  #54
Cmcmurray99's Avatar
Originally Posted by Urban Rogue
Here is mine. before I start doing a full custom interior
How did you do the ss in the doors?
Old Sep 9, 2017 | 07:46 PM
  #55
brettxw's Avatar
I am bringing this back from the dead...i want to wire some leds behind my door sill so when the door opens, they turn on and turn off when the door is closed. I'm not sure what wires to splice into? Any help would be appreciated
Old Sep 10, 2017 | 05:42 PM
  #56
cobaltssdude420's Avatar
It'd obviously be the map lights to tap into
Old Sep 11, 2017 | 02:30 PM
  #57
brettxw's Avatar
I understand that but there is no fuse labeled map lights or courtesy lights. I only see interior lights. Do you think if I follow this How to add on to courtesy lights.
that should work?
Old Sep 11, 2017 | 05:32 PM
  #58
Henry3959's Avatar
The cobalt uses the same 2 wires out of the BCM.
Old Sep 11, 2017 | 07:15 PM
  #59
brettxw's Avatar
Well, I have bad luck... I got a fuse tap and was going to tap into the interior light fuse..(far left under the 2amp) But the fuse tap is to large (I got the mini) and is being blocked by the red harness clip, it won't let it go in straight..so then I was going to splice into the wires in that how to... But they are zip tied so damn tight I can't even do cut the zip tie. Plus the wires are not the same color. Third wire on the left is not blue white on line, it's green and white. And the negative wire is not gray, it's like a light brown. So.. Now I gotta see if maybe I can follow the wires straight from the dome light and splice into that.... Such an easy installation had to turn into a pain in the butt.
Old Sep 11, 2017 | 07:32 PM
  #60
brettxw's Avatar
How can I see if any of those spare fuse slots turn off when the door is closed? Is it just wiring the power to fuse, putting the fuse in the slot and open and close the door to check?
Old Sep 21, 2017 | 08:18 PM
  #61
Wiring is a pain in the ass unless your a person who enjoys wiring lol
Old Sep 22, 2017 | 10:47 AM
  #62
Henry3959's Avatar
Are you sure your looking down far enough?
Mine are as clear as can be to locate and attached is a video showing the lights timeout 20 seconds after closing the door, takes 10 seconds to dim and as i open the door, turn back on.
The Dark Blue with white tracer is the power and the Grey is the ground.
Old Oct 5, 2017 | 11:31 AM
  #63
Henry3959's Avatar
Anyone purchased the Black Cat gauge face or LED kit? I'm interested in getting their SS face.
I did my own Sport Gauge package and now need to do my SS gauge package. The light output absolutely sucks... Bulbs are either burnt out or are what they are. Poor incandescent bulbs.
Thinking about changing out the other 2 gauges for Red as my whole theme is really red.
Old Oct 5, 2017 | 12:44 PM
  #64
Kobraa's Avatar
I had a custom black cat punisher ss cluster in my lsj with red LED kit. Lights looked amazing at night. Gauge face was extremely well done.
Old Oct 5, 2017 | 12:49 PM
  #65
Kobraa's Avatar
never got a picture of it installed apparently but here is my design, purchased with red led kit
Old Oct 5, 2017 | 03:06 PM
  #66
Henry3959's Avatar
Why would you put the ZZP on your dash?
Old Oct 5, 2017 | 03:29 PM
  #67
chevygirl2006's Avatar
Did my own
Old Oct 5, 2017 | 04:46 PM
  #68
Kobraa's Avatar
Car was entirely built with zzp parts.
06MetallicBalt
Jul 20, 2025 08:47 PM
ineedacobaltss
Nov 7, 2015 02:25 PM
dennis69
Oct 20, 2015 04:49 PM
patooyee
Oct 15, 2015 05:11 PM
