DDM HIDS Question
Old Apr 5, 2013 | 11:04 AM
gotboost?17's Avatar
Nothin Stock
DDM HIDS Question
I bought a set of hi/ low an fog hids from ddm about a month ago, last few nights the lights wouldnt turn off. r u guys using he error code eliminator? Thats the only thing i can think of.
Old Apr 5, 2013 | 11:13 AM
09BlueBaltSS's Avatar
Nope. Going 3 years now plug n play. I did pull the drl fuse as many of us do
Old Apr 5, 2013 | 11:23 AM
TommyP's Avatar
AWD > FWD
Error code eliminators are for cars with a "bulb out" warning light on them. Not needed on these cars. Are you using a relay setup? Could be that the relay got stuck open.
Old Apr 5, 2013 | 11:26 AM
Sox-Fan's Avatar
Got Brakes?
That's what I'm thinking too.
Old Apr 5, 2013 | 11:43 AM
Nothin Stock
Ive played with dlr fuse an no luck, an not sure what relay ur talking about, i have the power hooked up to the power terminal o the fuse box, ive only had problems these last few days, a locals having the same problem too
Old Apr 5, 2013 | 11:54 AM
Sox-Fan's Avatar
Got Brakes?
We don't know what you bought, so you tell us. Did you get a wiring kit with relays? I'd assume so if you have a power lead that you had to hook up. Never seen DDM's stuff but the replays are probably small square boxes, likely made out of clear plastic. Sound about right?
Old Apr 5, 2013 | 11:59 AM
Nothin Stock
Yeah small black box hooked to both headlights says hi/low relay on it i believe,
Old Apr 5, 2013 | 12:01 PM
Nothin Stock
So would that mean the relys going bad? They have a lifetime warraty
Old Apr 5, 2013 | 12:02 PM
Sox-Fan's Avatar
Got Brakes?
You're not confusing the ballasts with relays, are you? If you have relay kits and the relays are sticking then that will make the headlights stay on.
Old Apr 5, 2013 | 12:14 PM
Nothin Stock
Nope i know what ballasts r, must be the relay then ill keep u posted
Old Apr 5, 2013 | 12:15 PM
Nothin Stock
I just wanted to make sure i dint need the eliminator
Old Apr 5, 2013 | 12:22 PM
cobalt_sport08's Avatar
What do you have?!?!? I cant get my ballast to stay working for more than 5months it seems like with the HIDwerks kit.
Old Apr 5, 2013 | 12:57 PM
I have ddm's 35w digital ballasts on both fogs and head lights. Only issues I've ever had were receiving a doa ballast and after the first 2 years I had a ballast that wouldn't fire 100% of the time(had to flip the light 2-3 times) They warrantied the ballast both times. Can't really complain.
Old Apr 5, 2013 | 01:12 PM
Dang I was hoping you had the 55.w, Ive heard they they dont last as long as the 35w. And its really just the customer service that is really annoying me.. I got my kits 2 years ago and its always my fogs lights I have a problem with, which are the 55w. Ive probably gone through 4 ballasts and recently I got one that all it does is flicker. and the guy told me it was my wiring harness.. im rambling.... -__-
Old Apr 5, 2013 | 01:13 PM
Nothin Stock
Ddm says its the relay getting stuck, there sending another one out ill keep u guys posted if that fixes it
55w is a lot to pump into our small fog lights housings.
Old Apr 5, 2013 | 01:21 PM
Cobalt08LS's Avatar
should be using 35. no need for 55
Old Apr 5, 2013 | 01:27 PM
Sox-Fan's Avatar
Got Brakes?
By the way, if you have a relay kit you don't need to pull your DRL fuse.
Old Apr 5, 2013 | 01:58 PM
Nothin Stock
If i dont the hids will be on dring the day, canadian cars r wired differnce i believe i read from soundjunky. but as of rite now i put the fuse back in
Old Apr 5, 2013 | 01:59 PM
Sox-Fan's Avatar
Got Brakes?
what's wrong with your hids on during the day?
That's how mine are wired. What's the issue with that?
Old Apr 5, 2013 | 02:06 PM
nobody2u's Avatar
Because they'll run in DRL mode, which runs at a percentage of normal output for low beams at night. Apparently running them as DRLs can shorten the life of the ballast quite a bit. I'm no HID expert though, I still run halogens on my car.
Old Apr 5, 2013 | 02:09 PM
Sox-Fan's Avatar
Got Brakes?
Pretty sure that with relay harnesses all that the headlight wire does is trigger the relay. The relay only knows off/on. They will run full brightness whenever they are on.
Old Apr 5, 2013 | 02:16 PM
nobody2u's Avatar
Hm, I didn't know that. So your low beams will be on 100% and you won't have to deal with your tail lights being on in the day for example?
Old Apr 5, 2013 | 02:20 PM
Sox-Fan's Avatar
Got Brakes?
Exactly right.
The good thing about a relay kit is that you don't have to worry about a partially charged ballast. It's always on 100%.
Old Apr 5, 2013 | 02:26 PM
2009CobaltLT's Avatar
The reason for the DRL removal is for during the day, when you unlock your car, the lights come on, then when you open your door they turn off. then you turn the car on and they turn back on again. not good for bulbs to turn on and off repeatedly when they havent been warmed up from what I have been told. Also bulbs will last longer if they are not on all the time during the day
Ive got over 2 years on mine and havent had an issue yet. Got my kit from TRS though, Morimoto 35w ballasts
