debadging?
Old Apr 28, 2009 | 09:49 PM
BEASTmode632's Avatar
debadging?
how do i get the sticky **** off my car?
Old Apr 28, 2009 | 10:22 PM
Erod's Avatar
Moderator Alumni
pls read this
https://www.cobaltss.net/forums/announcement.php?f=68
moved.
also. go buy Goo Gone at Autozone etc
Old Apr 28, 2009 | 11:24 PM
Icydub's Avatar
Hairdryer and my best fingernail
Old Apr 28, 2009 | 11:43 PM
tuckedls's Avatar
i used general adhesive remover stuff. you can buy it and some hardware stores.
Old Apr 29, 2009 | 12:49 AM
wardzach2007's Avatar
fingernail, rub it off by rolling it back and forth with your thumb/fingers?
Goo Gone?
Elbow grease
Old Apr 29, 2009 | 07:39 AM
gearhead07's Avatar
ive been looking for that elbow grease ever where and i cant seem to find it> i looked at true valua and ace i even googled it and coulldnt find it
Old Apr 29, 2009 | 07:41 AM
JsavageSS/TC's Avatar
Old Apr 29, 2009 | 08:56 AM
n00b
It's called O'reily.
Old Apr 29, 2009 | 09:15 AM
Mindrot's Avatar
Kmart has the blue light special on elbow grease
Old Apr 29, 2009 | 09:31 AM
GingerBreadMan's Avatar
use ur fingernail
Old Apr 29, 2009 | 09:39 AM
theguard's Avatar
I found the best way was heating up the badge with a hairdryer and using a credit card to get it off (one that you don't need as it WILL wreck it), just use your finger/nail to get the sticky **** off, when it's warm it comes off pretty easily, then use lighter fluid to get the rest off. Lighter fluid is better than Goo Gone as I have both used them. The Goo Gone started to eat away at the paint so use lighter fluid. Then make sure you wash and wax the area. That's how me and my buddy did it a couple days ago.
Old Apr 29, 2009 | 09:42 AM
lobalt's Avatar
hair dryer, finger nail, thumb (blisters), then bug & tar remover, wash then wax w/ cleaner wax... in that order... @ least thats what I use...lol & i just took the door strips off the side of my LS this weekend... that was a 2 day process w/ everything else I had going on, but it looks GREAT... blister is almost gone
Old Apr 29, 2009 | 09:47 AM
68Vette's Avatar
Residue
One of the things I found to work great for this is Zippo lighter fluid or any lighter fluid as far as that goes. It will NOT harm your clear coat or paint!!! It also works well for removing road tar, bug guts, tree sap, on and on.
Old Apr 29, 2009 | 09:58 AM
blackbolt89's Avatar
use goo gone and then wash and wax it.
Old Apr 29, 2009 | 10:01 AM
1badBlueberrySC's Avatar
Your car is brand new man.... pull them bitches off... use your finger to roll the black foam **** up!
Wipe it down with goo-gone and then wax the area you just pulled the badges from!
Old Apr 29, 2009 | 10:07 AM
OrngBalt's Avatar
search "removing exterior trim" there is a post in there by me, with a video.
best way to do it, and not harm your car
Old Apr 29, 2009 | 12:27 PM
coco62584's Avatar
I heated the emblem up and worked in 80+ degree weather. Then jimmied it off with an old credit card. Once you get first little bit off, you can pretty much pull the rest off with your fingers. Then I used bug and tar remover to get rid of the residue. Then washed and waxed it.
Old Apr 29, 2009 | 12:53 PM
OrngBalt's Avatar
EEEKk... you guys make me cringe when you use a card... you got lucky, but it will definitely scratch. USE FISHING LINE!!!
It cuts through like a knife through butter
Old Apr 29, 2009 | 12:57 PM
zay52790's Avatar
Qft, a hairdryer and fishing line will work perfectly, then use some googone to help get the remaining glue off
Old Apr 29, 2009 | 01:08 PM
OrngBalt's Avatar
Bug and tar remover... let it soak after heating the badge a little. wipe it off and heat again. Fishing line to remove. Soak with bug and tar remover again. wipe, heat, base of thumb to "roll" the glue on itself. goo gone once it is all off to clean it totally. wipe clean, then use a spray polish or detailer (like meguiars) to clean it up and give it some shine.
Old Apr 29, 2009 | 01:22 PM
KnightBeforeLast's Avatar
Turtle Wax makes a bug and tar remover that worked like a miracle for me.
No heating, no elbow grease, spray it on, gooey stuff gone. It's a foam like gel so it stays on the bumper well which gives you time to let it soak in.
Old Apr 29, 2009 | 07:23 PM
ok i know the car is new but damn. i got mad blisters already and it barely did nething. and goo gone didnt work worth a ****. so im gonna try the bug and tar remover.
Old Apr 30, 2009 | 09:00 AM
lobalt's Avatar
blisters are worth it IMO... the bug & tar remover I used was the Turtle Wax spray, but Ive also used the turtle wax that comes in a can w/ the stupid lid, lol, i honeslty think the spray was better....
Old Apr 30, 2009 | 09:29 AM
Erod's Avatar
Moderator Alumni
um, are you letting it soak in for a bit? The stuff works great, I don't know what your doing..
dieGone
Sep 23, 2015 10:20 AM
toledobalt
Sep 2, 2015 07:04 AM
Asphalt Assault
Dec 8, 2006 03:51 AM
D4u2s0t
North East
May 9, 2006 07:23 PM
Wyoming_Bass
Apr 12, 2006 05:38 AM
