Dimples and a shorty
Old Jan 6, 2007 | 10:07 AM
RollOver360's Avatar
Well the other night i was debadging my car when I got to the GM ones on the fender. I popped them off and realized there were indents in the fender, must be so they knew where to place them. Has anyone else stumbled upon this? If so what have u done? I guess I will have to stick the GM things back up unless I can find something else.
I know my car is filthy, I gotta wash it after I finish the oil change.
Then I installed this shorty antenna, works great I get over 180 Channels. Way better then the stock antenna and the cheap eBay ones that bend when u drive.
later
I love my Sirius radio.....
Old Jan 6, 2007 | 10:12 AM
distillion's Avatar
i removed my lil GM badges on the fenders and never had any dimples, that does suck.
Old Jan 6, 2007 | 11:12 AM
PatDamanCobalt's Avatar
looks like you got hit with the corner of a shopping cart
Old Jan 6, 2007 | 11:37 AM
Switt23's Avatar
How did you... "pop" them off?
Old Jan 6, 2007 | 11:40 AM
MikeyMo84's Avatar
mine are gone....no dimples...just 1 small clearcoat chip cuz im an idiot
Old Jan 6, 2007 | 11:41 AM
Ljavy17's Avatar
thoght I was going to see pics of ur cute new gf.
Old Jan 6, 2007 | 11:43 AM
hatrickstu's Avatar
just to clear things up, you do know that antenna does not have anything to do with your satellite radio, right?
Old Jan 6, 2007 | 11:59 AM
Stouffer's Avatar
had the dealer remove mine when i purchased it, no dimmples. find a dent wizard or other paintless dent removal company. probably charge like $75-$150 but if you find a good tech you will never no they were there.
Old Jan 6, 2007 | 12:07 PM
rally's Avatar
shorty hell, start callin that a nub
Old Jan 6, 2007 | 06:33 PM
Hair dryer, plastic spatula, and some wiggling. Then some goo gone and rubbin it out.... lol
Well it kinda does when it goes through the radio channel...
It is pretty tiny, all it is, is the spot where the antenna screws on. with a cap on it.
No, not unless someone hit my car with a shopping cart in my garage when I bent down to get a paper towel... and its on both sides in the same spot.
I can't believe I am the only one with these "dimples". Mine is a 06 what year are urs?
later
Old Jan 7, 2007 | 01:16 AM
SSdan's Avatar
06 SS/SC and i don't have them....
Old Jan 7, 2007 | 01:20 AM
Boosted_SS's Avatar
[qoute]Well it kinda does when it goes through the radio channel... [/QUOTE]
well if you have an FM transmitter for your satellite radio you do realize that it is transmitting like 4 feet total? you better get perfect reception from 4 feet or i would take the **** back lol it's not like it gets sent to the muffler bearings, then bounces off the kooter valve, then gets redirected to the international space station, and then to the satellite , and finally back to your radio antenna.
Old Jan 7, 2007 | 02:39 AM
xspyder85x's Avatar
the factory antenna has nothing to do with satellite radio. they use their own.
Old Jan 7, 2007 | 10:21 AM
hatrickstu's Avatar
hey rollover do you play gears of war??? if you use this name i played with you the other day, added you as a friend
Old Jan 7, 2007 | 10:33 AM
Nope, not me.
well if you have an FM transmitter for your satellite radio you do realize that it is transmitting like 4 feet total? you better get perfect reception from 4 feet or i would take the **** back lol it's not like it gets sent to the muffler bearings, then bounces off the kooter valve, then gets redirected to the international space station, and then to the satellite , and finally back to your radio antenna.[/QUOTE]
I realize that my Sirius has its own antenna for recieving the channels(the black thing on my trunk that is 1.5 feet from my car antenna), BUT my car didnt come with Sirius so it goes through the radio using a transmitter, channel 89.1 is what mine is set at. Plus the factory radio doesnt have an imput jack so I cant use my Sirius that way, so I am forced to use the transmitter through the radio. Besides only sucky XM is available from the factory.
kooter valve......lol
later
Old Jan 7, 2007 | 11:46 AM
Boosted_SS's Avatar
later[/QUOTE]
actually if you had a black thing on your roof it doesn't transmit to your antenna it is hard wired directly into your radio. so outside interferience wouldn't be a problem. however i did figure out that you were using a sportster for sirius radio which does transmit to the radio via an FM transmitter. you will have problems in certain areas though. like if someone has something in the car next to you transmitting on the same channel your radio will be trying to pick up both channels. i realize this kinda problem will be limited but just wanted to clarify my previous comment.
Old Jan 7, 2007 | 06:52 PM
later
actually if you had a black thing on your roof it doesn't transmit to your antenna it is hard wired directly into your radio. so outside interferience wouldn't be a problem. however i did figure out that you were using a sportster for sirius radio which does transmit to the radio via an FM transmitter. you will have problems in certain areas though. like if someone has something in the car next to you transmitting on the same channel your radio will be trying to pick up both channels. i realize this kinda problem will be limited but just wanted to clarify my previous comment.[/QUOTE]
Yea I realize the interference problem but I have had this for 6 months now with no problems and where I live... in the boonies.. they probly think Sirius is a type of cereal.....lol
later
Old Jan 7, 2007 | 07:01 PM
ssaddiction's Avatar
where did you get the shorty antenna and how much?
Old Jan 7, 2007 | 07:08 PM
I unscrewed the stock antenna, then stuck a black cap on the threaded rod... and wallah! the nub antenna is invented. lol.
later
Old Jan 8, 2007 | 06:31 AM
xspyder85x's Avatar
just cut your stock antenna to about 1.5 feet. it looks way better. you will lose some reception though.
Old Jan 8, 2007 | 05:15 PM
TheCaptain's Avatar
I also removed the factory "whip" antenna, who needs it when you have awesome XM Radio. Again, black chunk of rubber/plastic screwed over the factory for a nub!
"You want serious satellite radio? GET XM!"
Old Jan 8, 2007 | 06:46 PM
MikeyMo84's Avatar
later
uhm...voila??
Old Jan 8, 2007 | 09:07 PM
I dont have to worry about the reception(sirius).... no point in ruining a good antenna.
later
chefhhr
Oct 26, 2015 10:36 PM
dieGone
Sep 23, 2015 10:20 AM
medic710
Sep 6, 2015 08:53 PM
