Dome light replacement
Old Mar 18, 2009 | 02:53 PM
IGotABalt's Avatar
would it be possibly to replace the dome light with a red light (LED maybe) just curious
Old Mar 18, 2009 | 02:54 PM
ddsscobalt's Avatar
yes its possible. sylvania lists what bulbs it has... dont mean to thread jack, but how do you get to the bulbs in the domelight. i was playing with it, but didnt wanna break anything but pulling
Old Mar 18, 2009 | 02:59 PM
cougar2588's Avatar
the cover snaps out. just take ur time with it and dont force it.
Old Mar 18, 2009 | 03:00 PM
IGotABalt's Avatar
^ ya that was my next question lol
Old Mar 18, 2009 | 03:01 PM
EmperorJJ1's Avatar
you just have to pull it down. there are 4 "hooks" that hold it on to the top plastic piece. Be careful with the switch because i broke mine and have had to replace it before
Old Mar 18, 2009 | 03:03 PM
IGotABalt's Avatar
aight thanx guys
Old Mar 18, 2009 | 03:04 PM
cougar2588's Avatar
yea just go at it with a butter knife or something not too sharp and slowly pop each clip out one by one.
Old Mar 18, 2009 | 04:11 PM
wantedSS/TC's Avatar
this is for balts with the sunroof, but when trying to remove the bulbs from the mirrors you need a pair of needle nosed pliers to pull the bulb out (pinch at the base of the bulb) as my fingers were too fat to get into the socket completely.
The interior is FAR brighter than the standard halogen bulbs that are in the lights. It's a must for looks and functionality!
Old Mar 18, 2009 | 05:40 PM
wardzach2007's Avatar
Yes it is. Replacements are
194 wedge bulbs.
Old Mar 18, 2009 | 06:12 PM
NCC-2000's Avatar
What's even better is putting the dome light in since GM screwed anyone with a sunroof by leaving it out.
Old Mar 18, 2009 | 06:40 PM
That and an armrest
Old Mar 18, 2009 | 06:44 PM
116Fanatic's Avatar
I can't put mine back on?? I could only get one clip back on but it seems like the roof pushes in so the others don't connect. any suggestions?
Old Mar 18, 2009 | 06:50 PM
Is there anything broken?
Old Mar 18, 2009 | 06:55 PM
116Fanatic's Avatar
I don't think so...i didn't take it off again because I thought what if i can't get ANY clips on if i do kwim?
Old Mar 18, 2009 | 06:57 PM
snake890217's Avatar
superbrightleds.com
Old Mar 18, 2009 | 07:00 PM
Originally Posted by snake890217
superbrightleds.com
x2!!!!!!
Old Mar 18, 2009 | 07:03 PM
asherby85's Avatar
Let me just start by saying that I have no idea what the bulb looks like for the cobalt. However, I replaced the bulb in my dome light on my old ION sedan with a orange led that I got from oznium.com
Found here: http://www.oznium.com/led-dome
This is how I got the dome light cover off: Stick my key on the side where the clip is at to push it in, comes right off.
the led comes with a bunch of different connectors and you just have to find the one that matches up with your dome light. The one I used isn't the same as the stock, but the way I used it, it worked.
Old Mar 18, 2009 | 07:05 PM
You probably are not putting in there correctly then. I doubt anything is broken.
Old Mar 18, 2009 | 07:17 PM
I think its called a festoon loop bulb or rigid loop bulb. I got mine on eBay before I knew about superbrightleds.com
Old Mar 18, 2009 | 11:32 PM
EmperorJJ1's Avatar
mine does the same ****. i had to get a screw driver where they "clip on" and hold the top plastic piece down with the screwdriver and push up on the "clear" one with my hand. took a bit of practice but worked well
Old Sep 8, 2009 | 11:52 PM
jmoretti13's Avatar
don't mean to thread jack but NCC-2000 said something about installing a dome light for balts with sunroof...what dome and how difficult to wire? Anyone know of any threads for this? need help?
Old Sep 9, 2009 | 12:26 AM
Cptn Pants's Avatar
https://www.cobaltss.net/forums/show...ght=dome+light
that's NCC-2000's dome light thread. It doesn't look that hard, but I didn't go that route for my lighting needs.
Old Sep 9, 2009 | 01:26 AM
Cobalt08LS's Avatar
not trying to thread jack but does anyone know how to replace the whole dome light assembly.
i went to install an led dome light and had to bend the terminals so it would be tight and its all messed up kept blowing fuses because i bent the terminals trying to get the bulb not to wiggle. so i went back to the stock bulb and now the bulb wont stay in all the way sometimes it works sometimes it doesn't. because the bulb is on top of the clips not actually sitting on the clips. so im just going to get a whole new assembly off ebay for 19 dollars
anyone know how to remove and reinstall the whole assembly?
Old Sep 9, 2009 | 02:29 AM
EmperorJJ1's Avatar
its pretty easy... too bad i had the inner assembly but threw it away. i messed up my switch
you may have to pull the headliner off and get it from the top thou
Old Sep 9, 2009 | 12:17 PM
Cobalt08LS's Avatar
ugh seriously.?
because my terminals are all bent n stuff n i was thinking of getting a new one the bulb is all the way up just barely enough to have power
its not sitting on the clips like it should
