Door Panel HELP!!
Old Aug 23, 2006 | 09:17 PM
MIMJoe's Avatar
Unhappy Door Panel HELP!!
OK I have the door panel off and I purchased the spray adhesive, but how do I get the arm rest area out. I want to put a red insert around the area that has all the window switches and door locks, but it looks like its bonded to the door panel?
Any help, tips, tricks, pics appreciated.
Old Aug 23, 2006 | 09:24 PM
wdsoccer's Avatar
I got a screwdriver and put it as level as i could with the stuff that holds it together, and then i got a wrench and tapped it till it was off then moved to the next one. Its a lot of work. What r u using to cover the insert?
Old Aug 23, 2006 | 09:47 PM
Young Money's Avatar
I just pulled it off...granted it took some force, but I pretty much just "popped" all the studs out. Not hard at all...but definitely not for the weak at heart.
Old Aug 23, 2006 | 11:06 PM
MIMJoe's Avatar
How did you get the part to stay back on? It looks like once you "pop" off the insert the plastic "tabs" are broken? How does it stay on after you break the "tabs"?
Old Aug 23, 2006 | 11:16 PM
wdsoccer's Avatar
I used Really tiny Screws and really good glue (seal-all). worked good. Check out my sig 2 see a pic of it.
Old Aug 23, 2006 | 11:28 PM
MIMJoe's Avatar
Thanks. The pics look great, but do you have any close ups? Did you put the seal all on the "tabs" after you put the insert back together with the door panel?
Old Aug 23, 2006 | 11:37 PM
wdsoccer's Avatar
Dont have any close ups yet i can get some in the next couple days. Yes i put the seal all on all the tabs when i put it back in. i need to redo my passenger door though. it looks like ****.
Old Aug 24, 2006 | 09:03 PM
MIMJoe's Avatar
I still can't figure out how to get the black plastic tabs loose? Did you dremel them off or what?
Old Aug 24, 2006 | 11:58 PM
wdsoccer's Avatar
they dont get loose they have to be broken off.
brickloaf
Show & Shine
56
Jun 18, 2019 12:51 PM
Extreme Dimensions
Sep 24, 2015 05:24 PM
dieGone
Sep 23, 2015 10:20 AM
The Rookie24
Sep 14, 2015 07:03 PM
chris88z24
Sep 8, 2015 01:55 PM
