door panel removal..??
Hey guys,
Curious if anyone knows how to pull the door panel off of a coupe? Every once in a while, my inside door handle "comes off the track" and gets disconnected from the car basically and won't open the door. Then after I open it from the outside handle, it's fine. I just want to pull the panel off and see what's up. it sounds worse than it is though.. lol.
Thanks..
Thanks..
There are two covers you need to remove to access screws. One is behind the handle, the other is in the arm rest pull thing. Once the covers are out, you'll see three screws, one up by the handle and two in the arm rest thing. Remove them, then just grab the door panel and pull. It'll pop off rather easy all the way around until you get to the tweeter, it's held in with one of those annoying metal clips. Once that lets go you can unplug the tweeter and pull the panel off the door to get at the back side and inspect the handle mechanism.
that's just lazy bro
and that's a big fat premium member......
This thread is a perfect example of why this site has server issues. There's just a ton of useless threads which can be avoided just by searching the forum
Last edited by hailcesar75; Aug 2, 2009 at 04:08 PM. Reason: Automerged Doublepost
So we really need four thousand "hey, it's friday, so let's make nine million useless one word posts"!!! Or the "hey, let's post up a bunch of pictures of **** because, after all, we never seen those before" But no, my one car-related post MUST be the problem with the server. Try again.
chris88z24
Sep 8, 2015 01:55 PM
