Fog light upgrades
Old Apr 27, 2012 | 06:02 PM
black08SS-TC's Avatar
Fog light upgrades
Ive been looking at the blazer fog light projectors on the retrofit source web site. Has anyone replaced there fogs with these? If so was it a direct fit? I called and they have gm part # and come upgraded with glass lens so they won't get all dull that's why I need new ones but they 45.00 for a set... Really cheap I think
Old Apr 27, 2012 | 06:56 PM
donald's Avatar
subd
Old Apr 28, 2012 | 12:06 AM
Crav3's Avatar
Which ones are these? Pic?
Old Apr 28, 2012 | 12:17 AM
rever3nce's Avatar
interesting
Old Apr 28, 2012 | 09:59 AM
breds2k's Avatar
dude. blazer fogs are such a disappointment!!!
They were highly anticipated at TRS, had beautiful output, color and cutoff! They demo'd them, and everything looked great.
Then people bought them. Ran HID's in them and nearly every single person with HID's melted the lights in a day or two.
They cannot handle the heat of hids at all!!!! this is not like people saying minih1's cant handle 55w hids or something, you litterally cannot have hids in these or they will melt.
But i bet some silverstar halogens in blazers are brighter than hids in factory ss fogs, i dont get why they suck so bad!
Old Apr 28, 2012 | 10:10 AM
breds2k's Avatar
ok so i do resent that post above a bit when I saw output shots with a 37.5w halogen bulb check it out:
Blazer Projector Fog Light Modification....(lots of pics)
Old Apr 29, 2012 | 06:19 PM
dude the cut off line looks sweet im just gonna run halogen bulbs in them anyway so no big deal. r they a direct replacement???
Old Apr 29, 2012 | 06:24 PM
TommyP's Avatar
AWD > FWD
not a direct replacement, would take some custom fitment/brackets. If you look at pics of the fog light housing and compare them to the blazer you'd see the big design difference. I would work on trying to mod the stock fogs. Make custom cutoff shields out of aluminum flashing and play around with bulb and shield spacing to try to get a blue cutoff if that's what you're going for. Stock fogs are not designed to handle the output of hids, so the optics for them are all wrong.
Old Apr 29, 2012 | 06:30 PM
well its not the cutoff line im worryed about stock fogs are all beatup cant see crap with them on i thought the stock lens were plastic and i know these r glass. correct me if im wrong tho
Old Apr 29, 2012 | 06:33 PM
TommyP's Avatar
AWD > FWD
stock lens is glass. They're gonna get beat up due to rocks and suck. You could always sand the lenses and clear coat them, though fog lights aren't actually supposed to help you see better, they're pretty much just for show. They'll help in actual fog but not a whole lot.
Old Apr 29, 2012 | 06:37 PM
yeah i know they were ok when new but thats about it... i guess ill see if i can clean them up with sanding. im gonna run 3000k halogen in them anyway. tryed leds they sucked a**
Old Apr 29, 2012 | 06:39 PM
TommyP's Avatar
AWD > FWD
yes leds aren't even close to as bright as a halogen bulb. At the moment there is no plug and play led bulb as bright as a halogen bulb. You should be happy with the yellow, they'll be pretty good in fog and rain. If you sand the lenses, be sure to clear them or it'll be even worse. Alternatively, measure the width and height of the lenses and see if you can find a suitable replacement. You could also find a set of fogs from another GM vehicle in a junk yard, they all use the same projector fogs as far as I've ever seen.
Old Apr 29, 2012 | 06:59 PM
Ok thanks man ill work something out. And yeah my friends tbss has the same style and they r also all beat up..
Zharrington_2010LNF
Feb 8, 2016 01:43 PM
RaginChopsuey
Oct 27, 2015 01:27 PM
dennis69
Oct 20, 2015 04:49 PM
HEATON
Oct 16, 2015 07:21 PM
dieGone
Oct 1, 2015 06:27 PM
