Fog Lights on 07 Lt sedan
Hello all,
Im wanting to add fog lights to my 07 Lt sedan. My car has the removable lower grilles. Ive found everything i need (relays harness, hid, fog lights, and lower grill with fog light holes).
I just wanted to make sure it will work before i order them.
Does the Fog Light housing attach to the lower grille insert? if not how does it attach to the bumper.
I plan on wiring them to a seperate switch.
All or any help with be appreciated.
Thanks ahead of time.
Derek !
Derek !
from the few pictures ive seen. Theres a ring that snaps on the fog light lower grilles and then the actual fog light housing bolts onto that ring then u just snap the lower grille in and and wire them up. But i dont wanna spend $150 on the grilles and lights for them not to work.
any advice will help.
thanks again all
thanks again all
it should work i mean some of them come with the fogs and some just have the black pieces i cant even member how mine mounted up cause i had a base model and i got the gt bumper and such
It won't work unless you get a new bumper or some custom brackets.
Check this thread for more info
https://www.cobaltss.net/forums/appe...-piece-230262/
I've done some research and still confused.. Found this site that sells the fog light grilles
Chevrolet Cobalt Replacement Driving Light Cover - 2005-2010 Chevrolet Cobalt - Replacement C015502
From the pictures I've seen and that picture it looks like maybe the foglight housing might or could attach to the grille insert. What do you think?
z28addiction
Sep 28, 2015 12:03 AM
