fog lights on base model cobalts...
Old Feb 27, 2006 | 05:12 PM
CobaltDude81's Avatar
what do u guys reccomend for adding fog lights onto a base model? has anyone done this yet?
Old Mar 1, 2006 | 09:45 AM
tallyphotog's Avatar
I was planning on ftackling this deal this weekend.
So far my issue is where to power them. The engine compartment fuse panel has a fuse for fog lights, so I was planning to run it into there.
Second is location, if you get under the lower grill on the front fascia, you'll see two of those black clippy deal right where a nice set of fog lights might go!
My plan was to pop out those clips and bolt the foggies through the already drilled holes.
If all goes well, I'll have a how-to for it next week.
Old Mar 2, 2006 | 11:29 PM
afireinside1582's Avatar
ive seen new inserts for the small "grilles?" on the bottom sides, they are just like the stock ones, but have molded in places for fog lights, i just need to remember where i saw them!
Old Mar 9, 2006 | 03:45 PM
SymbioteLT's Avatar
i was removing the interior trimming and I discovered that I have the wiring for the fog lamp, just not the switch, I have an LT without fog lights so im just going to buy the switch from chevy, plug it in and check the connections under the hood near where the factory fog lights would go see if I got power, i havent checked the fuse or power yet, I just know the wiring is there.
Old Jun 22, 2007 | 05:42 PM
CORVETTE007's Avatar
Hello
Have an '07 LT Cobalt (2dr) without foglights. Anyone ever figure out if you could add them, and if so what's the best way?
I've heard that you can replace the side grilles with factory one's containing the hole for the foglight. If this is the case, does anyone have any part numbers and then I suppose I'd need part numbers for the factory fogs etc...
Thanks!
Old Jun 22, 2007 | 08:27 PM
a couple weeks after my original post i added fog lights... heres a pic of them...
https://www.cobaltss.net/gallery/sho...hp?i=20666&c=3
Old Jun 22, 2007 | 08:39 PM
lucky_lellow06's Avatar
Looks good. Did you try putting the fogs behind the middle grill? I think that'd look pretty sweet.
Old Jun 23, 2007 | 11:23 AM
On yours it looks like the grille's are part of the molded bumper, on mine they look as though they are removeable. That's why I was wondering if I could replace the removeable grille's with one's that have fog light openings.
Old Jun 23, 2007 | 11:28 AM
Xavipheus's Avatar
Originally Posted by CORVETTE007
On yours it looks like the grille's are part of the molded bumper, on mine they look as though they are removable. That's why I was wondering if I could replace the removable grille's with one's that have fog light openings.
Yes you can, just go to any dealer parts department and have them order them for you. They are about 20 for each side
Old Jun 23, 2007 | 02:07 PM
thanks lucky lellow06. I didnt try putting it inside the middle grill because a friend of mine did that on his Honda Prelude and i didnt think it looked that great with something in the way of the beam...
RaginChopsuey
Oct 27, 2015 01:27 PM
footballplaya3k
Sep 30, 2015 09:39 PM
z28addiction
Sep 28, 2015 12:03 AM
