foglight bulb removal?
Old Mar 8, 2006 | 06:18 PM
eazyasone23's Avatar
Does anyone know how to remove the fog light bulbs? or do you actually have to take off the bumper to actually access them. Because looking at them for a lil bit of time its the only way I think you can actually reach them. Waiting to put on my new fogs bulbs in so any tips would be great.
Old Mar 8, 2006 | 06:21 PM
memphisr24's Avatar
I'd like to know this too because I will soon be adding HID's to my headlights and foglights. There are right ups on the healights but none on the foglight.
Old Mar 9, 2006 | 12:22 AM
memphisr24's Avatar
Bump ! ! !
Old Mar 9, 2006 | 02:11 AM
QuikFKR's Avatar
Once you pull out the headlights you can reach down, twist and pull the bulbs out. This is the easiest way
Old Mar 9, 2006 | 04:29 PM
thanks for the info...im just mad i gotta take out those headlights again. they are such a pain
Old Mar 10, 2006 | 12:46 AM
ok i did it tonite. first u gotta remove the headlight assembly. (driver side) you will be able to reach down into a lil compartment to access your fog light bulb. (pass side) your actually gonna have to remove the headlight assembly plus the headlight bracet, because the stock intake tube actually blocks you from gettin to your foglight bulb.
Old Apr 1, 2006 | 04:11 PM
SiVtEcDoYoU's Avatar
so about how long did it take you guys? 'cause im planning on adding some piaa yellows to my cousin's ride today.
Old Apr 1, 2006 | 05:10 PM
oaklandmr's Avatar
I did it a different way. If you lift the front of the car up, there is a black plastic piece on each side. If you take the 3 or 4 screws on the bottom of that out, pull the plastic down and you can reach right up in there. Its cake...took me like 5 min each.
Old Apr 1, 2006 | 05:39 PM
BooSSted's Avatar
^^^I did it that way as well. I found it was easier than taking out the headlights.
Old Apr 1, 2006 | 11:57 PM
piaa yellows, here i come.
Old Jul 10, 2006 | 09:23 PM
e to the x's Avatar
I was certainly wondering how to do this this afternoon. Good to know. I will probably do this over teh weekend when I have access to jack stands.
How to Guide
57
Oct 15, 2015 11:56 AM
royce777
Sep 28, 2015 07:11 AM
Extreme Dimensions
Sep 24, 2015 05:24 PM
katahdin_lubricants
Sep 20, 2015 07:24 PM
Getaway_Driver
Sep 8, 2015 09:41 AM
