Front grill removal
Old Jul 18, 2009 | 09:27 PM
Billy Baldone's Avatar
Front grill removal
Hey I just don't want to break anything here.what is the best way to remove my front grills on my 09 T/C SS.I want to paint them gloss black
Thanks
Old Jul 18, 2009 | 09:41 PM
Mindrot's Avatar
Upper one is pretty simple to figure out by looking at it. Or search for instructions. But the lower one you have to squeeze under the car and GENTLY pull the plastic tabs downward and push the grille outward and not inwards towards the car.
Old Jul 19, 2009 | 12:48 PM
riko540's Avatar
The upper grille was alittle tricky for me. Pop out the ceter of the round clips and then take the 2 bolt like things off the back of the bowtie. Then just be careful removing the upper grille.
The lower grille just has 5 or 6 clips that you pull off and than just push the grill outwards.
Old Jul 19, 2009 | 01:04 PM
tuner923's Avatar
for the lower grille remove the metal clips and then pop it out the front. the upper grille has plastic retainers on the top remove them then reach in and remove the front bowtie. then to the left and right of the bowtie the is a plastic screw on each side. they are flat and unscrew with your fingers its that simple. the rears are even simpler.. just push them out to the rear
Old Jul 19, 2009 | 03:26 PM
JoshuaVnyrd1817's Avatar
For the upper make sure you take out the 2 plastic screws put in to the foam guard. It took me like 30 minutes to realize I forgot those.
I just did the same thing and makes such a difference.
Old Jul 20, 2009 | 01:52 AM
Cobalt08LS's Avatar
you need a square drive to get those screws out. people say u can use a phillips but you cant itll strip it and you wont be able to get the screw out
Old Mar 14, 2010 | 07:27 PM
ssturbo305's Avatar
sub'd
SSLOW06
Oct 1, 2015 07:21 PM
Tupp
Sep 30, 2015 08:18 PM
n20saturn
Sep 30, 2015 12:26 AM
grampss
Sep 27, 2015 08:51 PM
