Gear Position Indicator
Old Mar 1, 2014 | 10:44 AM
Tony Luckert's Avatar
Lightbulb Gear Position Indicator
Being an electrical engineer and having my 'balt just come into the "I can do whatever the hell I want to" status, I thought it would be cool do create an LED lighted shifter knob. After doing some research and such, I saw a shifter from a BMW I think that had a seven segment display built into the shifter that displays the gear number. I went "ooooh I could totally build that." So, my question before I go a pure hardware route is, does the ECM or the 5 speed transmission have a position sensor for the 5 speed manual transmission?
Old Mar 1, 2014 | 10:47 AM
I dont think theres a position sensor, but it knows what gear youre in based off of speed and rpm
Old Mar 1, 2014 | 10:49 AM
Happen to know if that is a reading that can be pulled from the ECM? I haven't been able to find any highly detailed schematics on it.
Old Mar 1, 2014 | 10:53 AM
I can try looking at alldata in a bit
Old Mar 1, 2014 | 01:10 PM
sundevil07's Avatar
This is a feature on the rpd in LNF's. And yes from watching it it monitors wheel speed and rpm to determine which gear you're in.
Old Mar 1, 2014 | 01:26 PM
andrewcarr1993's Avatar
Boost by gear on aftermarket boost controllers does the same thing. Learns the gears by wiring in the speed and RPM.
Old Mar 2, 2014 | 08:01 AM
So, last night I did some work on the stock shifter playing around and I think I got a good idea going here. I only have one LED embedded right now, but it took me a while to find 5 blue LEDs. I'm going to put a red one under the reverse side.
First LED embedded.
Modified cap.
LED on under modified cap.
Old Mar 2, 2014 | 11:02 AM
MaxDugas's Avatar
In for results! Nice idea!
Old Mar 2, 2014 | 11:38 AM
ItalianJoe1's Avatar
I think the only way to pull the ECM's gear indication would be via the CAN bus, it's not a pin-out type of output. Only used for transmission calculations and such. I don't see that alone being able to power the light setup you want without some sort of computer handling it.
Old Mar 2, 2014 | 11:56 AM
armcclure's Avatar
The lsj does not know all gears. It knows 1st and 2-5.
Old Mar 2, 2014 | 02:01 PM
kzak104's Avatar
if the gear indicator is on the shifter, wouldnt u be looking at the shifter to see what gear your in anyways lol
Old Mar 2, 2014 | 02:33 PM
Can't remember who (maybe CAD88 I think) put LEDs before in the shifter pattern.
Old Mar 2, 2014 | 06:16 PM
Well, the LEDs in the shifter aren't for me to look at, there it going to be a display in the dash for that. I looked around on the interwebs and didn't find anything either. I have several different microprocessors that I can play around with. Have some more information on that CAN bus?
Old Mar 2, 2014 | 06:52 PM
Joe09SS's Avatar
Or you can just get a RPD display like me
But that is a nice touch.. But usually your hand is on the shifter, maybe shifting.. So you wouldn't see it and if you have to look down to see what gear you're in... Then maybe you shouldn't be driving manual. Lol just kidding.
Old Mar 3, 2014 | 08:39 AM
Cobalt08LS's Avatar
Raxiom Mustang Digital Shift Knob - Manual GL-1021 (79-14 All) - Free Shipping
i like this pretty neat
Old Mar 3, 2014 | 08:40 PM
He can't get an RPD though.
Old Mar 3, 2014 | 09:30 PM
C_A_D88's Avatar
Bmartz I have never done such a thing I have LEDs everywhere else tho lol
Old Mar 3, 2014 | 09:33 PM
Interesting, hopefully it turns out
Old Mar 4, 2014 | 09:02 AM
I like the Mustang idea too. But.... lets just get one thing working at a time :p
Old Mar 4, 2014 | 10:47 AM
I guess I'm thinking of somebody else then lol
Old Mar 7, 2014 | 12:48 AM
Update, work on this is slow because of other projects and work.
I am going to hide all the wiring through the shifter knob and boot.
Lamp Test
Lamp Test w/ Cap
Sl0wbaltSS
Nov 21, 2018 11:11 PM
hacadacalopolis
Oct 28, 2015 06:09 PM
biniecki
Oct 25, 2015 02:23 PM
cw383
Sep 30, 2015 12:41 AM
DocSvensk
Sep 27, 2015 02:24 PM
