Gen 4 vs black stocks
Old Sep 24, 2013 | 02:59 PM
iToastie's Avatar
Take apart the Gen 4s and paint the chrome black, problem solved
Old Sep 24, 2013 | 03:38 PM
cOHbalt's Avatar
was thinking about doing that.... Knowing my luck they condensate
Old Sep 24, 2013 | 03:47 PM
z062007vette's Avatar
Sir_Hiro on here just got his Retro's done by someone out in PA. I'll link him to this thread and see if he can make a comment.
Old Sep 24, 2013 | 04:01 PM
Sir_Hiro's Avatar
Guys name is Jeff Cerreto
Old Sep 24, 2013 | 04:05 PM
kcg795's Avatar
What's the point in putting HIDs in your stock headlights if you have to aim them down? Not only do you lose your distance by aiming them down, you also lose your distance by the excess foreground light. I know HIDWerks sells HID bulbs that actually "tilt" in the proper place for low beam and high beam. But bi-xenon lights from anywhere else, like DDM Tuning, are a joke. I'd say either get the Gen 4s and swap out the crappy halogen projector for a set of Mini H1s or go with the stock headlights and do a retrofit with those with any projector you want.
Old Sep 24, 2013 | 04:18 PM
Spawne32's Avatar
With good bulbs the stock housings are not bad at all, i use phillips night guide bulbs in my stock headlights and they are plenty bright. However if you must have HID's I would recommend the Gen4 depos which are outstanding and look the best out of all of the ebay projector lenses. Some car's can get away with HID bulbs in factory housings, some cant, the design of the factory housing on our car's just doesnt work well with HID's scatters far too much light in the wrong directions.
Old Sep 24, 2013 | 04:59 PM
cOHbalt's Avatar
What's the cost to make them compared to the cost to buy. Is it hard to make them
Yourself?
Old Sep 24, 2013 | 05:52 PM
kcg795's Avatar
It could range from less than $300 to over $600. It depends what you want. I did my Mini H1 retrofit for around $300, including ballasts. My EvoX-R retrofit was almost $600 because I went with XBALED halo rings, premium shrouds, OEM bulbs (Philips 85122s), and new TYC stock headlights from Amazon. I'm reusing my Morimoto 3Five ballasts I've had for 2 and a half years with AMP to D2S adapters. So the cost depends on what you want. With the XBALED halos, I custom made a relay harness with a fuse tap that goes into the DRL fuse slot so they restore my DRL functionality.
Old Sep 24, 2013 | 05:53 PM
cOHbalt's Avatar
Okay that makes sense. Ill have to look into it more. Thanks a lot for your help
Old Sep 24, 2013 | 06:21 PM
Mr.Tozzi's Avatar
I got gen 4 black and they look decent, they fit well if you take the time to align it with the body of the car. the light output is good enough for me and I only have a cheap ebay hid kit. I want to paint the crome part in black also but I don't have the time for that right now. I'm happy with the depo gen4 but if I had the time and money I would build a set of retros, they look better.
Old Sep 24, 2013 | 06:42 PM
  #36
chevygirl2006's Avatar
When people say aim them down they don't mean aim them all the way to the ground. I couple clicks down is fine. I can see pretty far in front of me doing it that way. And my HIDS are from HIDWERKS and they are the real bi xenon bulbs. I've seen people with projector style lights with HIDS coming towards me blind me more than stock headlights with HIDS.
Old Sep 24, 2013 | 06:50 PM
  #37
qwank's Avatar
yup, you just want them slightly lower so they don't blind people. it doesn't take much.
Old Sep 24, 2013 | 06:52 PM
  #38
Black oem is what I'd get if you can't afford retros. The chrome in the Gen 4s is one if the reasons I sold mine, hated it.
Old Sep 24, 2013 | 06:54 PM
  #39
TheSlowGT's Avatar
Originally Posted by cOHbalt
Yeah I know that would happen but retros are so expensive and I have no idea how to make them nor do I wanna screw it up
i had no ******* clue when i made mine. i did my research and spent only $150. am still happy with my results
Old Sep 24, 2013 | 07:18 PM
  #40
cOHbalt's Avatar
Probably going to get the black stocks. I'll do some research on retros before I buy hids. I hate the crome on the gen 4's I rather not pay money then crack them open expecting them to condensate. How do you aim the stocks down ?
Old Sep 24, 2013 | 07:21 PM
  #41
With an Allen wrech on top
Old Sep 24, 2013 | 07:24 PM
  #42
cOHbalt's Avatar
Awesome sounds simple
Do you have any pics ?
Old Sep 24, 2013 | 07:30 PM
  #43
kcg795's Avatar
That's how we all learn how to do our own retrofit. Research! Mini H1s aren't so bad. Some trimming is necessary. When I did my EvoX-R retrofit, I bought new headlights for them to go into and took my time. I learned as I went along because you do run into problems.
Old Sep 24, 2013 | 07:31 PM
  #44
qwank's Avatar
6mm allen
Old Sep 24, 2013 | 07:35 PM
  #45
cOHbalt's Avatar
This is a good idea. If I get the black stocks this will free up my oem Crome ones to experiment with
Old Sep 24, 2013 | 11:48 PM
  #46
Sir_Hiro's Avatar
if u have the money..Do the FX-Rs retrofits. The mini H1s are decent but the best outthere currently is FX-Rs
Old Sep 25, 2013 | 01:07 AM
  #47
kcg795's Avatar
FX-Rs are nice, but I did EvoX-Rs for the best distance.
Old Sep 26, 2013 | 05:27 PM
  #48
TheSlowGT's Avatar
Size:  243.2 KB i was having halo issues in the last pic
Old Sep 26, 2013 | 05:29 PM
  #49
TheSlowGT's Avatar
last pic with the projector on
Old Sep 26, 2013 | 09:50 PM
  #50
cOHbalt's Avatar
Honestly that looks great! You said you spent 150?
