Got the strut bar put on! pics!
the bolts to attach the spark plug cover to threaded holes on the engine.
i couldn't find them anywhere around here went to a hardware store, home depot, pepboys and advanced auto.
http://i245.photobucket.com/albums/g...neCover005.jpg
6mm the length is 2.5 inches
thanks!
yeah you can buy them from him for only 5 dollars. i had to because no one around here had them.
the cover screws into the 2 threaded holes on top of the valve cover
mine came today im just awaiting the bolts.
also when your installing there is a 10mm bolt containing a little bracket holding one of the fuel lines on the top right side i took the bolt out to get the cover to sit flush i just did it for a test fit and it fit fine. when the bolts come im going to undo the bolt move the bracket and put the cover on and screw into place than put the bolt back on and the bracket in place.
ill go out to my car now and see if i can get some pics. idk if i can becuse its dark.
will let you know
heres a pic of the 10mm bolt you want to loosen and take out than you move that clip out of the way so the line is out of the way so the cover can sit flush
heres a zoomed out pic for you
hope this helps
will let you know
hope this helps
