H.I.D. problem
Old Apr 24, 2010 | 08:10 PM
seandooley's Avatar
H.I.D. problem
Ok i hooked up my fog lights no problem....
headlights i needed a wireing harness.. for my 2006 so i plug everything together and the H.I.D.s dont work...my turn signals work but not the H.I.D.s
I think the problem is everything was plug n play except the three wires a red (hi) white(low) and black (grnd) they are supposed to connect to the old plug that used to connect to the head light the issueis that old connector has orange pink and black wires so i dont know the correct wire to connect to.
if anyone could give some insight i would appreciate it .. I have been working on this for like 6 hours ...starting to **** me off
ok so i just tried every different slot possible...still doesnt work, so now i have no idea why only my H.I.D. headlights dont work everything else works....
Last edited by seandooley; Apr 24, 2010 at 08:10 PM. Reason: Automerged Doublepost
Old Apr 24, 2010 | 08:15 PM
Gestapo007's Avatar
when it comes to HID hookups i need to see whats going on untill i can solve it. I was having trouble with a Honda accord and it turned out that it needed reverse polarity to work, so i needed to swap the plug for the ballast and plug it in backwards to get them to work
Old Apr 24, 2010 | 09:02 PM
seandooley's Avatar
I'll be trying that tommorrow Thanks for the idea!.....im done with it today ....i put 10 hours on it today 30 min fog lights 2-3 hours painting the housings and the rest spent trying to figure out this headlight issue...
Old Apr 24, 2010 | 09:16 PM
Gestapo007's Avatar
its almost always a wiring issue and not the HID's themselves. I imagine its stock headlights. Take apic of what it all looks like and ill see if i can help you out
Old Apr 24, 2010 | 09:18 PM
ecot3c inside's Avatar
im not even going to try the headlights without a harness, although I hooked up my fog hid's without a harness and they flicker retarded. so I have 2 harness's coming in. sometimes you have to switch the hookups around for them to work, like it doesnt look like it hooks up, because the security pin connector is on the otherside . ect , but they do.
turbochargedss2012
Sep 20, 2023 12:17 PM
yellow dragon
Sep 28, 2015 09:49 PM
Iceberg
Sep 28, 2015 01:31 PM
DocSvensk
Sep 27, 2015 02:24 PM
Adiaz1ss
Sep 26, 2015 11:51 PM
