Hate to do this... hid problems..
Old Sep 29, 2011 | 02:34 PM
searched around, saw some somewhat similar threads but different problems..
anywho, just got this Xentec HID kit off ebay...
Bi XENON 9003 H4 9007 H13 Dual High Low Beam HID KIT | eBay
u can kinda see the pics for how its set up on there...
anywho i installed it last night.
PROBLEM/S: The lights work. But, idk what causes it but sometimes when i switch them on they dont work. either one side, the other, or both. also, when this happens, i hear a noise coming from the the passenger side ballast. it especially turns off if i hit the highbeams
im sure i hooked them up right... the wires u need to connect to the stock harness are as follows:
new kit stock wires
blue red (drl)
black black (ground)
white orange (highbeam)
the kit came with basically a relay sort of ballast. the stock plug goes into it, and it kinda loops around to make it to the hid bulb evetually after a few hookups. no power or gorund wires needed.
anywho please help if u have dealt with this kit, anythings appreciated really, even trolls
Old Sep 29, 2011 | 02:42 PM
user 70823082's Avatar
Might need a better relay harness.
Old Sep 29, 2011 | 02:43 PM
faaak
Old Sep 29, 2011 | 02:45 PM
Yea, I'm pretty sure you need to ground the HIDs, also did you take out your DRL fuse? Apparently that's a big if you don't.
Old Sep 29, 2011 | 02:46 PM
rephrase's Avatar
I have the same kit, with no relay harness. works great every day? Go through and double check everythings connected tight.
Old Sep 29, 2011 | 02:53 PM
what do you mean ground? heres the deal, the kit came with 3 naked wires, and a plug they fit into in order to plug into your 3 wire stock bulb plug. so i matched them up and did that. u saying the black ground wire needs to be tapped into the chassis?
also didn't know i'd need to remove the drl fuse... wouldn't that make the lights not work if i took that out?
thanks for ur help btw i appreciate it
did u ground the black wire or remove the drl fuse?
Last edited by riceburner; Sep 29, 2011 at 02:54 PM. Reason: Automerged Doublepost
Old Sep 29, 2011 | 03:12 PM
bumptronica
Old Sep 29, 2011 | 03:19 PM
I can't really see the relay harness it came with so I really can't tell you. but yea apparently having the DRL fuse in is not good for it.
Old Sep 29, 2011 | 03:36 PM
k thanks i guess ill check it out. anyone else have an idea?
Old Sep 29, 2011 | 03:53 PM
bump?
Old Sep 29, 2011 | 04:01 PM
TommyP's Avatar
AWD > FWD
A real relay harness will almost guaranteed fix this, I've seen it plenty of times, the car cannot put out enough power to initially start up the bulb. Sometimes it can, sometimes it can't. A relay harness will ensure that they hid kit is getting enough power. I had this same issue in the past, and a relay harness was the fix
Old Sep 29, 2011 | 04:04 PM
thanks tommy u know where to get this or have a suggestion, as in which one u got? i'm a total hid noob haha
ftr, i actaully was reading on a somewhat similar thread about something like this last night that u were in
Old Sep 29, 2011 | 04:07 PM
TommyP's Avatar
AWD > FWD
HID Relay Harness
Just make sure you put the black relay box INSIDE the engine bay, it needs to stay dry.
Old Sep 29, 2011 | 04:14 PM
k thanks. umm dumb q but does it come with one or 2? haha
Old Sep 29, 2011 | 04:17 PM
heathkidder's Avatar
Should only need one my fogs used to do the samething till i changed the ground wire
Old Sep 29, 2011 | 04:28 PM
what u mean changed the ground wire? actually just keep pming me haha
Old Sep 29, 2011 | 05:14 PM
so why do i need to remove the drl fuse???
Old Sep 29, 2011 | 05:27 PM
rephrase's Avatar
I didn't remove anything. I plugged in the wires to the ballast and plugged the bulbs in. No ground, no nothing. If anything you might have got a defective kit?
edit: I don't have bi xenon kit, i just have single. sorry.
Old Sep 29, 2011 | 05:36 PM
TommyP's Avatar
AWD > FWD
You have an 06 so you don't have to. the 07-10s have the low beam as the drl which is damaging to hids. Also riceburner since you have an 06 you don't have a drl fuse to remove either, so no worries there.
Old Sep 29, 2011 | 05:39 PM
^^^ THANKS that clears that up lolz
well i ordered relays from buyhids.com so hopefully that works. tonight: install the fog hids! ill post back on here once i figure it out, and still open to any other suggestions
Old Sep 29, 2011 | 05:47 PM
zerosk8ter83's Avatar
sounds like you dont have a good ground
chefhhr
Oct 26, 2015 10:36 PM
allpro666
Oct 6, 2015 08:11 PM
Sep 30, 2015 07:22 AM
dieGone
Sep 23, 2015 10:20 AM
Regalgs
Sep 17, 2015 02:27 PM
