Headlight Clear Coat Peel
Old Jan 20, 2012 | 06:28 PM
ebone2's Avatar
his guys my clear coat on my Gen 1's headlights are shreding...does anyone know how to fix this... ill post up pics in a little bit...Need tips
Also i have small leak in my headlights, cause when i wash my car my headlights get fogg/misty in the headlights, does anyone know how to fix this
Old Jan 20, 2012 | 06:34 PM
Black SS/SC 06's Avatar
This is pretty common with these. I think your best bet is to replace the lenses or try one of the kits they sell at auto part stores for headlight repairs.
Old Jan 20, 2012 | 06:37 PM
ebone2's Avatar
and the dirt u see on the lens isnt on the outside, its on the inside
Old Jan 20, 2012 | 11:06 PM
blackonwhitecobalt's Avatar
peeling concern
i have the same problem with the peeling clear coat...what im planning to do is wet sand it and then re-clear it with a better clear
as for the leak, im not sure
Old Jan 20, 2012 | 11:24 PM
mkulrey13's Avatar
shouldn't have gotten them...lol never heard of anyone fixing this issue.
Old Jan 21, 2012 | 01:46 PM
Bluelightning's Avatar
Got Bewst?
Same thing happened to me. The lenses in Gen headlights are junk. The best way is to find a set of stock lenses and put them on. Looks better because they are smoked and no more crap lens.
Old Jan 21, 2012 | 01:51 PM
04_IRL's Avatar
you have two options, you can either use stock lenses as stated, or you can take your existing lenses and take them off, buy some rubber butyl and line the lenses with it, heat it back up in the over at 225, and press it back together, that should fix your leaking problems, then, wet sand them with 1000 and have someone clear coat them, a body shop should be able to do it between $50-$100.
Sl0wbaltSS
Nov 21, 2018 11:11 PM
Solaris99
28
Mar 15, 2017 01:22 PM
Fearedbynone
Apr 14, 2016 03:25 AM
SlowSaturn
Sep 28, 2015 11:03 AM
