Headlight help!
Ok, so this problem stared a while ago. When I unlock my car, the headlights turn on everytime. But when I actually turn the car on, the drivers side light dosen't always turn on. I found if I either juggled the wires, or lighty hit the headlight, it turns on. So I bought a used wiring harness from a member here, and it seemed to fix it for a couple days. But then it starded to do it again. Any ideas? I'm not sure if the bulbs going bad, cause like I said, it turns on everytime I unlock my car, and it always turns on once I hit the headlight a couple times. Any sugestions? I have Eurodezigns bulbs, just plug n play, nothing special, in a 100% stock headlight set up.
Don't forget the high beams and low beams are in the same bulb because its a dual filament bulb. So I guess check that. My ls didn't come with an alarm (its aftermarket) and my HIDs are only single filament (no highbeams) so I'm not sure if that effects anything.
brickloaf
Sep 21, 2015 02:17 PM
