Headlight question
Old Apr 14, 2008 | 09:27 PM
CASol's Avatar
Headlight question
Anyone know what this is or what it does? Because it just fell off and dont know what to do. Its on the back side of the driver side headlight and 2 wires are taped into the wire harness for the headlights
Old Apr 14, 2008 | 09:40 PM
yellowltcoupe22's Avatar
looks to me like a resistor for led bulbs to keep em from blinkin fast. do you have leds for turn signals?
Old Apr 14, 2008 | 10:05 PM
CASol's Avatar
nope, this is all OEM
Driver side only
Old Apr 14, 2008 | 10:07 PM
hmm.. that wasnt on my stockers.. guess someone else would have to give it a shot then.. sorry man
Old Apr 14, 2008 | 10:16 PM
CASol's Avatar
thanks for the try
Old Apr 14, 2008 | 10:37 PM
weavagra's Avatar
It is a government tracking device. Hurry up and wrap it in tinfoil.
I would go to the dealer you bought it from and ask them.
Old Apr 14, 2008 | 11:07 PM
Dustin's Avatar
Did you buy the car new?
Old Apr 14, 2008 | 11:19 PM
smartdude24's Avatar
That looks totally strange... that box is wired into your stock blinker wires... dunno why. Maybe that's where you add the blinker fluid
I say you crack open that box and see what's inside of it and post a pic
Old Apr 15, 2008 | 01:01 AM
ProjectBolt08's Avatar
im going with a resistor also but it looks "non" factory to me... i just got some hella headlights so ill see if mine has those tomorrow & post
Dave
Old Apr 15, 2008 | 03:07 AM
CASol's Avatar
Thats what I thought
Brand new off of the truck
But if i open it, the fluid will leak out
Dave
Thanks for the feed back and let me know
I thought it looked strange and it just fell off when i went to reinstall the lights. The lights work normal with out it
Old Apr 15, 2008 | 04:27 AM
EmperorJJ1's Avatar
those are t tap connections that it uses so no its not factory
Old Apr 15, 2008 | 04:41 AM
silverfae7's Avatar
Do you have a kill switch and is it your left turn signal?
Old Apr 15, 2008 | 04:42 AM
CASol's Avatar
One wire was to the turn signal and no i dont have a kill switch, just the factory alarm
Old Apr 15, 2008 | 09:02 PM
CASol's Avatar
I think it has to do something with the temp reading, it didnt go above 60 today until the temp droped below 65 then it reads normal. Im really confused now
Old Apr 15, 2008 | 09:05 PM
did you try unpluggin it completely and seeing if it made any difference? i still think its some kinda resistor cuz it doesnt look factory with the way its just spliced in.
Old Apr 15, 2008 | 09:10 PM
juststickit124's Avatar
I looks like a part to aftermarket fog lights, so they go on with the parking lights maybe. If someone had the car before you they probably just left this in.
Mnatvyc1223's Avatar
yup, it is using splices so it's probably not factory. and u said ur lights work fine without it... do they blink any faster without it? if not then it's not any sort of resistor... just take it off and leave it off... and if it doesnt affect anything then crack it open and post a pic.
Old Apr 15, 2008 | 09:43 PM
CASol's Avatar
ok guys, read what I have posted already, your asking answered questions.
but thanks for the responces
Old Apr 15, 2008 | 09:48 PM
I honestly can't see it having to do with temp reading... I mean it's a secluded box attached to the wires that cause your turn signal bulb to blink... so it should only get intermittent power when the driver signal is on...
Old Apr 15, 2008 | 09:51 PM
redSSBalt's Avatar
It's definetly aftermarket. The Manufacture doesn't use T-taps for any connections. It's connected to the turn signal and ground on that headlight. If your lights work fine, and the turn signal blinks normal. You could remove it without any problems.
Exactly!! Since whoever installed it used the turn signal wire for power. It will only get power when the signal blinks!!
Old Apr 15, 2008 | 10:39 PM
Omnigear's Avatar
dont go below 55mph or it will blow up.
Old Apr 15, 2008 | 11:29 PM
omg EPIC post
Old Apr 15, 2008 | 11:35 PM
Joeyavhu's Avatar
If I worked for GM, I would stick random boxes that do nothing onto peoples cars all the time, this way they would start posts about it wondering what they are.
You should open the box, there might be a little note that says something along the lines of... Fooled you. Lol.
Old Apr 15, 2008 | 11:57 PM
CASol's Avatar
LOL that would be funny and fun to do
Old Apr 15, 2008 | 11:59 PM
MikeyMo84's Avatar
figure out what it is yet?
