Headlights
Are they aftermarket lights ? If so they grade of polycarbonate they used for the lens is not rated for the heat of the DRL being on all the time . It breaks down the plastic , hence the peeling appearence . Anything short of sanding the lens down below the surface of the problem and then bring back the gloss with 400 , then 800 then 1000 , 1500 grit paper with a polishing compound ....there really isnt a easy fix .
If u have stock headlights that are painted like what looks like in your sig pic .....what u used to seal them up and the paint itself can be causing a chemical etching on the inside of the lens . The same process as above applies , you cant just wipe off or buff chemically etched plastic . The Vapors from Silicone based sealents ( I always recommend urethane based sealents ...silicone is evil ) will attack the plastic lens , also if the you didnt let the paint dry long enuff ( I recommend at least 3-4 days ) before u reassemble the headlights , the vapors of the paint trapped in the headlight housing will eventually chemically etch the inside of the lens . If the paint was fully cured before assembled it would not let of any gases that would etch .
I dunno, I will take pics tonight so you can see what I am talking about. I was thinking about sanding the top and painting eyelids on them to cover it up. On a side note though, do you think doing the eyelids black will look ok? Thanks for the help
this is the **** u need....
autozone or adavanced auto parts pep boys etc....you cvan find this...
i forgot the exact name but its known as a headlight "restorer"
i had to use it for my sentra se-r awhile back...
its like a wax u use to buff that plastic looking stuff off...its good stuff. sorry i couldnt get ya the name but i do know exactly what your talkling about.
1500 is too rough....go a little softer..
someone on here is sellng there headlights for 80, they look nice...ima try and find that thread for ya
Last edited by BlackMachine; May 25, 2008 at 12:11 PM. Reason: Automerged Doublepost
brickloaf
Sep 21, 2015 02:17 PM
