Headlights Stripped With Bleach:
i think 1 guy did on a how to on here. i will try and find it
Edit here is the link : https://www.cobaltss.net/forums/how-...ics%5D-282150/
Just did this last night, I bought two containers of outdoor strength bleach and poured them in a plastic hefty tub. Then you just throw the shrouds in and let them sit for a couple hours and presto you have plastic. Just make sure you don't let any metal screws or anything go in otherwise they will corrode very quickly and it won't look like the bleach is doing anything at first, you have to give it a good hour before you notice much of anything.
anytime you can get down to a BARE plastic finish and paint it properly like a raw plastic bumper cover from a manufactuer its MUCH MUCH better.
i stripped my subaru headlights by using a light media and blasting it off. however this cant be done with certain manufactuers. reason being is some use heavy chrome dip thats extremely hard to blast off and eventually you will blast away or weaken the plastic. . however it worked well for me. then i prepped the plastic with 600 grit wet and a plastic cleaner paste and scuff pad to finish them off. guarentee if i left the lenses off it would take a very long time before you start seeing chips and stuff.
brickloaf
Sep 21, 2015 02:17 PM
