Help with DDMTuning 9007 HID Kit
Soooooooooooooooooooo last night me and a buddy (mccullj) where installing my new audi r8 style head lights. I bought DDM Tunings 9007 HID kit to match the LEDs and my fogs. Well...we hooked everything up and no matter what we did, we could never get the passenger side turn signals to work. We switched bulbs back and forth on both sides. Switched harness. Everything. We even pulled all the HID stuff and put stock stuff in and it worked. Only with the HIDs would those bulbs not work. Anyone got any info for me? Thanks. Mccullj can vouge for me...
Did you signals work before this?
Just wondering as the main headlight harness shouldn't effect the signal harness. Unless if you ran 55w ballasts and upon ignition you could have fried the harness if you didn't have a relay.
I am Mr. HID
I am Mr. HID
Just noticed now - you have LED blinkers? Do you have a resistor so the harness sees the load as an incandescent bulb since they have the correct wattage for the relay to see that the bulb is working - therefore causing it to blink normally.
Sep 28, 2015 12:51 PM
