Help HID kit on old camaro
im looking for a HID kit to put on my 1967 Camaro and i was wondering which one is the best i dont know the difference between 6000k 8000k etc thanks in advance here are some i fount on ebay
7" Round Semi SEALED Glass Lens Red LED Projector Headlights 6000K H4 2 HID | eBay
8000K Blue White Hi Low HID 7" Round H6014 H6024 Red LED Projector Headlights | eBay
6000K White Bi Xenon HID 7" Round H6024 Semi SEALED Red LED Ring Headlights | eBay
7" Round H6017 H6024 Red LED Ring Headlights 10000K Blue Bi Xenon Slim HID | eBay
H6015 H6017 H6024 7" Round Clear Headlight w Red Halo Bi Xenon 8000K HID Kit | eBay
Stay the hell the way from PnP HID kits and those fake projector lights. They have very poor light output. Also, unless you're trying to raise awareness for Autism, stay away from blue. Stick to 4,300k or 5,000k. Instead, check into Morimoto's Sealed7 Round Headlights at Morimoto Sealed7 Round Headlights. Or just figure out how to retrofit a projector into a 7" housing yourself. Just don't do HID kits.
I'd go 5000k. The number us the temperature. Different temps are different colors. The lower the temp the brighter the light. So 4000 is yellow and it is very visible to the human eye. Then 5000 is basically white, which is also bright. 6000 white with blue tint. Then it goes all the way up to purples and pinks. Which I'd stay away from. 8 is blue I believe. So if you want show go for the colors. If you want great function go with a lower temp. Also, buy a quality kit. Others will not last long and don't shine as bright. Some companies temps are colored slightly different so make sure it has a picture or something so you know what you're getting
Buy a good kit from xenondepot or theretrofit source, also some guys say that kensun are really good too.
Just don't buy HID ebay cheap kit, they are not bright at all and wont last very long. Also retrofit a projector in your headlight yourself, its pretty easy to do if you take your time.
Otherwise look at this:
It would be the best for your camaro and you will have a great light output.
get these Hella conversion lamps, and run you headlights off of a relay connected directly to your battery and you'll have more than enough light without ruining the classic looks of your Camaro.
My Hella Lights :: Vision Plus 7" Round Conversion Headlamp
Sep 28, 2015 12:51 PM
